@pierre-gilles, while checking the integration tracking page, there are 2 integrations that have been released for some time but are not yet integrated into the store. Could you look into why? I checked and they do have the gladys-assistant-integration label
Philips TV → gladys-assistant-integration.json: file too large (> 100 KB)
MeteoSwiss → manifest.gladys_version: declaring source "houses" requires ">=5.2.0" at minimum (older Gladys releases reject a dynamic source they do not know)
Bitcoin Monitor → manifest.widgets.1.label.en: must NOT have more than 30 characters; manifest.widgets.1.label.fr: must NOT have more than 30 characters
The errors are here: https://integration-store-storage.gladysassistant.com/rejected.json
Thanks @cicoub13 for the report!
Philips TV: fixed in 1.0.2. The manifest is now 84 KB instead of 119 KB (same content, just more tightly formatted), and a test prevents it from exceeding 95 KB. It should be accepted on the next indexer run ![]()
I’ll take care of it right away ![]()
Hello, I was on vacation at that time and completely missed your ping!
It will be fixed in a few minutes for the meteoswiss integration, thanks!
