Hi! I’m introducing a new integration for my Swiss friends (and not only?): Météo Suisse for Gladys
For your information, MétéoSuisse is a service of the Swiss Confederation, provided by the Federal Office of Meteorology and Climatology, attached to the Federal Department of the Interior (DFI). It is therefore a fairly accurate service for Switzerland.
Features:
- Support for the native weather widget
- Plus 3 graphs over 24 hours: temperature, precipitation, and wind/gusts.
- Each graph can display a different location, or home by default.
- Available in French and English, no account or API key required.
Météo Suisse data; unofficial community integration with no affiliation.
Your feedback is welcome!
Hi everyone,
The version 1.2.0 of the MétéoSuisse integration is available, with four new scene triggers: precipitation, frost risk, heatwave and strong gusts.
The settings are done directly in each scene: you choose the house, the threshold among the proposed values and the period to monitor: 1, 3, 6, 12 or 24 hours. Each scene can therefore have its own settings.
A few examples of automations:
Avoid unnecessary watering: if at least 1 mm of precipitation in one hour is forecast in the next 6 hours, disable watering.
Protect the plants: if the forecast temperature drops to 2 °C or less in the next 12 hours, send a notification to remember to bring them in.
Anticipate the heat: if the forecast temperature reaches 28 °C in the next 6 hours, close the shutters.
Bring in the awnings: if gusts of at least 40 km/h are forecast in the next 3 hours, run the corresponding scene.
The forecasts are checked every 15 minutes, even without a displayed widget. A risk already reported does not trigger the scene with each update: it must first disappear from the monitored period before it can trigger again.
These triggers use forecasts, not official MétéoSuisse alerts.
Release and details of version 1.2.0
Following up: the version 1.3.0 actually adds the official MétéoSuisse alerts
A new trigger allows you to choose, directly in the scene, the location, the phenomenon, and the minimum danger level (2 to 5).
For example: a storm alert of level 3 or higher can send a notification, or a wind alert can trigger the scene to retract the awnings.
The official feed is checked every 60 seconds. The scene is triggered upon receipt of a confirmed alert, even if it starts later, and again if its level increases. Count on about 1 to 2 minutes after web publication, depending on the cache and network.
The four triggers based on forecasts remain available.
Release and details of version 1.3.0
