Integration - SNMP
Hello everyone! I present to you SNMP, an external integration for Gladys 5.1+ that reads your SNMP (v1, v2c, v3) network devices and turns them into Gladys devices: reachable or not, response time, uptime, traffic, CPU, battery… Everything stays local, nothing goes through a cloud.
What the Integration Does
Each SNMP device becomes a Gladys device. You choose what it reports with profiles:
Profile What Gladys Receives For Which Devices
(always) Reachable (yes/no), response time (ms), uptime (days) All
interfaces Per port: active link, incoming and outgoing throughput (kbit/s) Switches, routers, Wi-Fi access points
host CPU load, used memory, fullest disk (%) NAS, Linux/Windows servers
ups Battery charge, autonomy, low battery, mains presence, voltage, charge, power Eaton, APC UPS with network card…
Custom OID Any OID, with category, unit, and scale Everything else (NAS temperature, toner…)
An OID can also be modifiable: it becomes a switch in Gladys, controlled by a SET SNMP. Useful for a PDU outlet or a PoE port.
Each device displays a local badge, or unreachable when it no longer responds.
Scenes and Dashboard (Gladys 5.1)
Triggers — one event per change, never on each query:
  • An SNMP agent no longer responds (variables: name, host, reason)
  • An SNMP agent responds again (variables: name, host, outage duration in minutes)
  • A network interface changes state (active / down filter)
Scene Actions — they never stop the scene in case of failure, they return success and error:
  • Read an SNMP value
  • Write an SNMP value (cut a PDU outlet, restart a PoE port…)
  • Query an agent now
« SNMP Agents » Widget — how many devices respond, one line per device with its response time, a « Query » button. Choose a device in its settings to also see its live values (CPU, memory, battery…).
Example: « if the UPS switches to battery, send me a message and turn off the NAS », or « if the box has not responded for 5 minutes, cut then restart its outlet ».
Installation and Configuration
  1. Enable SNMP on your devices. The easiest way: v2c with a read-only community (choose yours instead of public). SNMPv3 authPriv (SHA + AES) is supported.
  2. In Gladys (5.1 minimum), install the SNMP integration from the integrations catalog.
  3. In the Configuration tab, list your devices, separated by commas, in the format host[:port];name;profiles:
192.168.1.1;Router, 192.168.1.10;NAS;host, 192.168.1.20;UPS;ups
  1. Click Test Connection: each device tells if it responds, how long it takes, and its system name.
  2. Add the devices from the Discovery tab.
To follow switch ports, add your own OIDs, or use different credentials per device, paste a JSON list instead (see the documentation). Two buttons help fill it: List Interfaces (index and name of each port) and Browse an OID (to find the right value in a manufacturer’s MIB).
Known Limitations
  • No automatic discovery: devices are declared manually.
  • No SNMP traps yet, only polling (once per minute at most).
  • CPU, memory, disk, and UPS load are displayed in the « unknown » category with a % unit, due to a lack of suitable Gladys category.
  • On a large network, increase the refresh interval (e.g., 300 s) to avoid overloading the history.
Links and Feedback
This is a first version: your feedback interests me! Tell me which devices you have tested (brand, model, SNMP version), what works, what is missing. For a bug, a GitHub issue with the logs (without the community or keys) helps a lot.
Isn’t there any way to allow for automatic discovery?
Because doing it manually… It’s not very user-friendly! :innocent:
Great idea, it’s done! :slightly_smiling_face: Version 1.1.0 adds automatic discovery.
How to do it:
  1. In Configuration, set your SNMP community if it’s not public, then save.
  2. Go to the Discovery tab and click Scan.
  3. Devices that respond to SNMP appear with their name. Click Create for those you want to monitor.
host profiles (CPU, memory, disks) and ups (UPS) are detected automatically. No need to manually fill in the list anymore.
Limitations:
  • It works with SNMP v1/v2c, on port 161, on Gladys’ local network.
  • Devices only in v3, on another port or behind a router still need to be declared in the list.
  • Some devices do not respond to broadcast requests: they must also be added manually.
  • Remember to reserve the IP of your devices on your DHCP server. If the IP changes, the device reappears as a new device.
I haven’t been able to test on much hardware yet. Tell me what the scan finds at your place, or what it misses, with the brand and model.
