I'm starting... by fleeing another system for Gladys
First launch in home automation, and I started with a first mistake: the system dir***s. I quickly realized that it only works with external links… the system sends everything to geeglo before the configuration is even finished… If you use a VPN on your phone, it quickly becomes impossible to use.
So I looked for a model that works and switched to Gladys. I took an old PC on which I installed a Linux server, then Docker and Gladys. And now I’m learning.
Already the system works, and I was able to do my first integration: my dishwasher, then my printer. Then I made my second mistake: a Philips Wiz lamp. It took a few attempts to realize that it’s actually a closed system and you need a plugin (in Matterbridge, despite the Matter logo on the bulb box), which gives me a few errors…
So there you go, I think that given the stability, I’ll be in this community for a long time )
Hello everyone!
Welcome to you to discover everything Gladys has to offer
Welcome @eThor :smiling_face:
Welcome to Gladys
Question: I tried Matterbridge plugins for Wiz, but both are failing… One is external and seems to have been abandoned since last year, the other is a ‹ Gladys Assistant ›. Where should I report the error I encountered during the plugin installation? It’s just missing a variable « OnOffOutlet »… It’s an ‹ ai-factory ›.
Hi
Did you use matterbridge-ai-factory-wiz-connected-ampoules-et-luminaires-philips-wiz-slv-etc from [PLUGIN REQUEST] WiZ (Philips WiZ) · Issue #35 · GladysAssistant/matterbridge-ai-plugin-factory · GitHub ???
I’m afraid it might not be maintained :neutral_face:
Yes, indeed. Okay, I’ll check the differences with the other one… like textually to spot if there’s something that jumps out at me
Thanks cicoub13
