Energy tracking is coming soon to Gladys ⚡️
I’ve just finished the documentation, and I’m open to feedback before publishing it on Monday :grinning_face_with_smiling_eyes:
The documentation in French (temporary test link) : Surveillez votre consommation énergétique avec Gladys Assistant | Gladys Assistant
The documentation in English (temporary test link) : Monitor your energy consumption in Gladys Assistant | Gladys Assistant
Is your case unique or does it concern other Alsatians?
If it concerns other Alsatians, I’d appreciate it if you added the rates to the repo GladysAssistant/energy-contracts, this will allow adding the prices of Alsatian contracts once and for all and make them available to the whole community :slight_smile:
To give you an example, @prohand made a PR recently for « Gaz de Bordeaux »:
I’d be glad if you created a specific topic to discuss it!
That will work correctly but it will be less plug-and-play than for a Lixee TIC Zigbee, because you’ll need to create the features manually in the MQTT integration (nothing too complicated)
This is part of the documentation mentioned above :slight_smile:
Great! Are those Zigbee devices? If so, it will be plug-and-play.
For MQTT, there’s a bit of manual work to do :slight_smile:
