Alors, j’ai tout repris de zéro :
- Reset de la distrib WSL => install de la distrib Ubuntu 24.04.4LTS
- Passage des commandes une par une.
Pas de problème au lancement du front.
Par contre, au lancement du server, j’ai ceci et le site n’est pas accessible :
chouille@PC-Chouille:~/gladys/server$ npm start
> gladys-server@ start /home/chouille/gladys/server
> cross-env NODE_ENV=development nodemon index.js
[nodemon] 2.0.7
[nodemon] to restart at any time, enter `rs`
[nodemon] watching path(s): *.*
[nodemon] watching extensions: js,mjs,json
[nodemon] starting `node index.js`
2022-04-01T20:14:35+0200 <info> job.purge.js:17 (Job.purge) Deleting all background jobs created before = Fri Mar 25 2022 19:14:35 GMT+0100 (Central European Standard Time)
2022-04-01T20:14:35+0200 <debug> gateway.forwardWebsockets.js:14 (Gateway.forwardWebsockets) Gateway: not connected. Prevent forwarding event.
2022-04-01T20:14:35+0200 <debug> brain.train.js:59 (Brain.train) Training brain...
2022-04-01T20:14:35+0200 <debug> brain.train.js:61 (Brain.train) Brain trained!
Initialising OpenZWave 1.6.1051 binary addon for Node.JS.
        ZWave device db    : /usr/local/etc/openzwave
        User settings path : /home/chouille/gladys/server/services/zwave/node_modules/openzwave-shared/build/Release/../../
2022-04-01T20:14:36+0200 <info> index.js:19 (Object.start) Starting example service
2022-04-01T20:14:36+0200 <info> index.js:16 (Object.start) Starting MQTT service
2022-04-01T20:14:36+0200 <info> updateContainer.js:13 (MqttHandler.updateContainer) MQTT: checking for required changes...
2022-04-01T20:14:36+0200 <info> service.start.js:40 (Service.start) Service mqtt is not configured, so it was not started.
2022-04-01T20:14:36+0200 <info> index.js:16 (Object.start) Starting zwave service
2022-04-01T20:14:36+0200 <info> service.start.js:40 (Service.start) Service zwave is not configured, so it was not started.
2022-04-01T20:14:36+0200 <info> index.js:14 (Object.start) Starting Xiaomi service
2022-04-01T20:14:36+0200 <info> index.js:14 (Object.start) starting GoogleActions service
2022-04-01T20:14:36+0200 <log> index.js:16 (Object.start) Starting Zigbee2mqtt service
2022-04-01T20:14:36+0200 <warn> service.start.js:44 (Service.start) Unable to start service zigbee2mqtt PlatformNotCompatible [Error]: SYSTEM_NOT_RUNNING_DOCKER
    at Zigbee2mqttManager.init (/home/chouille/gladys/server/services/zigbee2mqtt/lib/init.js:15:11)
    at async Object.start (/home/chouille/gladys/server/services/zigbee2mqtt/index.js:17:5)
    at async Service.start (/home/chouille/gladys/server/lib/service/service.start.js:33:7)
2022-04-01T20:14:36+0200 <info> index.js:18 (Object.start) Starting TP-Link service
2022-04-01T20:14:36+0200 <info> index.js:17 (Object.start) Starting eWeLink service
2022-04-01T20:14:36+0200 <debug> gateway.forwardWebsockets.js:14 (Gateway.forwardWebsockets) Gateway: not connected. Prevent forwarding event.
2022-04-01T20:14:36+0200 <info> service.start.js:40 (Service.start) Service ewelink is not configured, so it was not started.
2022-04-01T20:14:36+0200 <info> index.js:15 (Object.start) Starting Bluetooth service
2022-04-01T20:14:36+0200 <debug> bluetooth.start.js:14 (BluetoothManager.start) Bluetooth: Listening Bluetooth events
2022-04-01T20:14:37+0200 <error> index.js:15 (process.<anonymous>) unhandledRejection catched: Promise {
  <rejected> Error: EAFNOSUPPORT, Address family not supported by protocol
      at new Hci (/home/chouille/gladys/server/services/bluetooth/node_modules/@abandonware/noble/lib/hci-socket/hci.js:74:18)
      at new NobleBindings (/home/chouille/gladys/server/services/bluetooth/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:25:15)
      at Object.<anonymous> (/home/chouille/gladys/server/services/bluetooth/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:546:18)
      at Module._compile (internal/modules/cjs/loader.js:1085:14)
      at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      at Module.load (internal/modules/cjs/loader.js:950:32)
      at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      at Module.require (internal/modules/cjs/loader.js:974:19)
      at require (internal/modules/cjs/helpers.js:101:18)
      at module.exports (/home/chouille/gladys/server/services/bluetooth/node_modules/@abandonware/noble/lib/resolve-bindings.js:13:12)
      at Object.<anonymous> (/home/chouille/gladys/server/services/bluetooth/node_modules/@abandonware/noble/index.js:2:49)
      at BluetoothManager.start (/home/chouille/gladys/server/services/bluetooth/lib/commands/bluetooth.start.js:16:20)
      at Object.start (/home/chouille/gladys/server/services/bluetooth/index.js:16:22)
      at Service.start (/home/chouille/gladys/server/lib/service/service.start.js:33:21) {
    errno: 97,
    code: 'EAFNOSUPPORT',
    syscall: 'socket'
2022-04-01T20:14:37+0200 <error> index.js:16 (process.<anonymous>) Error: EAFNOSUPPORT, Address family not supported by protocol
  errno: 97,
  syscall: 'socket'
2022-04-01T20:14:37+0200 <info> index.js:15 (Object.start) Starting Tasmota service
2022-04-01T20:14:37+0200 <info> index.js:64 (Object.start) Starting CalDAV service
2022-04-01T20:14:37+0200 <info> index.js:20 (Object.start) Starting Open Weather service
2022-04-01T20:14:37+0200 <info> service.start.js:40 (Service.start) Service openweather is not configured, so it was not started.
2022-04-01T20:14:37+0200 <info> index.js:13 (Object.start) Starting usb service
2022-04-01T20:14:37+0200 <info> index.js:19 (Object.start) Starting Telegram service
2022-04-01T20:14:37+0200 <info> service.start.js:40 (Service.start) Service telegram is not configured, so it was not started.
2022-04-01T20:14:37+0200 <info> index.js:16 (Object.start) Starting RTSP service
2022-04-01T20:14:37+0200 <info> index.js:18 (Object.start) Starting Philips Hue service
2022-04-01T20:14:37+0200 <debug> scene.init.js:12 (SceneManager.init) Scene.init
2022-04-01T20:14:37+0200 <debug> device.init.js:34 (DeviceManager.init) Device : init : Found 0 devices
2022-04-01T20:14:37+0200 <debug> gateway.forwardWebsockets.js:14 (Gateway.forwardWebsockets) Gateway: not connected. Prevent forwarding event.
2022-04-01T20:14:37+0200 <info> device.calculateAggregate.js:38 (DeviceManager.calculateAggregate) Calculating aggregates device feature state for interval hourly
2022-04-01T20:14:37+0200 <debug> device.calculateAggregate.js:50 (DeviceManager.calculateAggregate) Aggregates device feature state policy = 180 days
2022-04-01T20:14:38+0200 <debug> scheduler.init.js:9 (Scheduler.init) Scheduler.init
2022-04-01T20:14:38+0200 <info> index.js:63 (Server.<anonymous>) Server listening on port 1443
2022-04-01T20:14:50+0200 <warn> device.calculateAggregate.js:95 (Socket.<anonymous>) device.calculateAggregate stderr: DatabaseError [SequelizeDatabaseError]: SQLITE_PROTOCOL: locking protocol
    at Query.formatError (/home/chouille/gladys/server/node_modules/sequelize/lib/dialects/sqlite/query.js:415:16)
    at Query._handleQueryResponse (/home/chouille/gladys/server/node_modules/sequelize/lib/dialects/sqlite/query.js:72:18)
    at afterExecute (/home/chouille/gladys/server/node_modules/sequelize/lib/dialects/sqlite/query.js:246:27)
    at Statement.errBack (/home/chouille/gladys/server/node_modules/sqlite3/lib/sqlite3.js:14:21) {
  parent: [Error: SQLITE_PROTOCOL: locking protocol] {
    errno: 15,
    code: 'SQLITE_PROTOCOL',
    sql: 'PRAGMA journal_mode=WAL;'
  original: [Error: SQLITE_PROTOCOL: locking protocol] {
    errno: 15,
  sql: 'PRAGMA journal_mode=WAL;',
  parameters: undefined
2022-04-01T20:14:50+0200 <warn> device.calculateAggregate.js:101 (ChildProcess.<anonymous>) device.calculateAggregate: Exiting child process with code 1
2022-04-01T20:14:50+0200 <debug> gateway.forwardWebsockets.js:14 (Gateway.forwardWebsockets) Gateway: not connected. Prevent forwarding event.
2022-04-01T20:14:50+0200 <error> device.onHourlyDeviceAggregateEvent.js:22 (DeviceManager.onHourlyDeviceAggregateEvent) Error: DatabaseError [SequelizeDatabaseError]: SQLITE_PROTOCOL: locking protocol
    errno: 15,
    errno: 15,
    at ChildProcess.<anonymous> (/home/chouille/gladys/server/lib/device/device.calculateAggregate.js:102:23)
    at ChildProcess.emit (events.js:400:28)
    at maybeClose (internal/child_process.js:1058:16)
    at Socket.<anonymous> (internal/child_process.js:443:11)
    at Socket.emit (events.js:400:28)
    at Pipe.<anonymous> (net.js:686:12)
From previous event:
    at DeviceManager.calculateAggregate (/home/chouille/gladys/server/lib/device/device.calculateAggregate.js:76:19)
    at async /home/chouille/gladys/server/lib/device/device.onHourlyDeviceAggregateEvent.js:11:5
    at async /home/chouille/gladys/server/lib/job/job.wrapper.js:17:7
    at async DeviceManager.onHourlyDeviceAggregateEvent (/home/chouille/gladys/server/lib/device/device.onHourlyDeviceAggregateEvent.js:20:5)
    at async EventEmitter.<anonymous> (/home/chouille/gladys/server/utils/functionsWrapper.js:13:7)
2022-04-01T20:14:50+0200 <info> device.calculateAggregate.js:38 (DeviceManager.calculateAggregate) Calculating aggregates device feature state for interval daily
2022-04-01T20:14:50+0200 <debug> device.calculateAggregate.js:50 (DeviceManager.calculateAggregate) Aggregates device feature state policy = 365 days
2022-04-01T20:15:00+0200 <info> scene.checkCalendarTriggers.js:24 (SceneManager.checkCalendarTriggers) Checking calendar triggers at Fri, 01 Apr 2022 18:15:00 GMT
2022-04-01T20:15:03+0200 <warn> device.calculateAggregate.js:95 (Socket.<anonymous>) device.calculateAggregate stderr: DatabaseError [SequelizeDatabaseError]: SQLITE_PROTOCOL: locking protocol
    errno: 15,
    errno: 15,
2022-04-01T20:15:03+0200 <warn> device.calculateAggregate.js:101 (ChildProcess.<anonymous>) device.calculateAggregate: Exiting child process with code 1
2022-04-01T20:15:03+0200 <debug> gateway.forwardWebsockets.js:14 (Gateway.forwardWebsockets) Gateway: not connected. Prevent forwarding event.
2022-04-01T20:15:03+0200 <error> device.onHourlyDeviceAggregateEvent.js:27 (DeviceManager.onHourlyDeviceAggregateEvent) Error: DatabaseError [SequelizeDatabaseError]: SQLITE_PROTOCOL: locking protocol
    errno: 15,
    errno: 15,
    at async /home/chouille/gladys/server/lib/device/device.onHourlyDeviceAggregateEvent.js:14:5
    at async DeviceManager.onHourlyDeviceAggregateEvent (/home/chouille/gladys/server/lib/device/device.onHourlyDeviceAggregateEvent.js:25:5)
2022-04-01T20:15:03+0200 <info> device.calculateAggregate.js:38 (DeviceManager.calculateAggregate) Calculating aggregates device feature state for interval monthly
2022-04-01T20:15:03+0200 <debug> device.calculateAggregate.js:50 (DeviceManager.calculateAggregate) Aggregates device feature state policy = 1825 days
2022-04-01T20:15:16+0200 <warn> device.calculateAggregate.js:95 (Socket.<anonymous>) device.calculateAggregate stderr: DatabaseError [SequelizeDatabaseError]: SQLITE_PROTOCOL: locking protocol
    errno: 15,
    errno: 15,
2022-04-01T20:15:16+0200 <warn> device.calculateAggregate.js:101 (ChildProcess.<anonymous>) device.calculateAggregate: Exiting child process with code 1
2022-04-01T20:15:16+0200 <debug> gateway.forwardWebsockets.js:14 (Gateway.forwardWebsockets) Gateway: not connected. Prevent forwarding event.
2022-04-01T20:15:16+0200 <error> device.onHourlyDeviceAggregateEvent.js:32 (DeviceManager.onHourlyDeviceAggregateEvent) Error: DatabaseError [SequelizeDatabaseError]: SQLITE_PROTOCOL: locking protocol
    errno: 15,
    errno: 15,
    at async /home/chouille/gladys/server/lib/device/device.onHourlyDeviceAggregateEvent.js:17:5
    at async DeviceManager.onHourlyDeviceAggregateEvent (/home/chouille/gladys/server/lib/device/device.onHourlyDeviceAggregateEvent.js:30:5)
2022-04-01T20:16:00+0200 <info> scene.checkCalendarTriggers.js:24 (SceneManager.checkCalendarTriggers) Checking calendar triggers at Fri, 01 Apr 2022 18:16:00 GMT
L’erreur sur le bluetooth me semble normal, pas d’accès aux périphériques de l’hôte Win10.
- Comment désactiver le service ?
Par contre, l’erreur SQLite est peut être la source du problème ?
