Problème installation environnement de DEV
Hello :slight_smile:
Je demande un peu d’aide car je souhaite commencer à regarder pour dev sur Gladys et donc installer l’environnement de DEV.
Je suis la doc du site Mettre en place un environnement de développement sous Windows | Gladys Assistant
Cependant je rencontre des erreurs au moment de l’installation du backend lors du « npm install »
Voici l’erreur:
root@DORIAN-PC:~/gladys/server# npm install
> cpu-features@0.0.4 install /root/gladys/server/node_modules/cpu-features
> node buildcheck.js > buildcheck.gypi && node-gyp rebuild
sh: 1: cannot create buildcheck.gypi: Permission denied
> ssh2@1.9.0 install /root/gladys/server/node_modules/ssh2
> node install.js
internal/modules/cjs/loader.js:905
  throw err;
Error: Cannot find module '/root/gladys/server/node_modules/ssh2/install.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
    at internal/main/run_main_module.js:17:47 {
  code: 'MODULE_NOT_FOUND',
  requireStack: []
npm WARN gladys-server@ No description
npm WARN gladys-server@ No repository field.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/mocha/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-windows-arm64@0.14.32 (node_modules/esbuild-windows-arm64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-windows-arm64@0.14.32: wanted {"os":"win32","arch":"arm64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-windows-64@0.14.32 (node_modules/esbuild-windows-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-windows-64@0.14.32: wanted {"os":"win32","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-windows-32@0.14.32 (node_modules/esbuild-windows-32):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-windows-32@0.14.32: wanted {"os":"win32","arch":"ia32"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-sunos-64@0.14.32 (node_modules/esbuild-sunos-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-sunos-64@0.14.32: wanted {"os":"sunos","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-openbsd-64@0.14.32 (node_modules/esbuild-openbsd-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-openbsd-64@0.14.32: wanted {"os":"openbsd","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-netbsd-64@0.14.32 (node_modules/esbuild-netbsd-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-netbsd-64@0.14.32: wanted {"os":"netbsd","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-s390x@0.14.32 (node_modules/esbuild-linux-s390x):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-s390x@0.14.32: wanted {"os":"linux","arch":"s390x"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-riscv64@0.14.32 (node_modules/esbuild-linux-riscv64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-riscv64@0.14.32: wanted {"os":"linux","arch":"riscv64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-ppc64le@0.14.32 (node_modules/esbuild-linux-ppc64le):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-ppc64le@0.14.32: wanted {"os":"linux","arch":"ppc64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-mips64le@0.14.32 (node_modules/esbuild-linux-mips64le):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-mips64le@0.14.32: wanted {"os":"linux","arch":"mips64el"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-arm64@0.14.32 (node_modules/esbuild-linux-arm64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-arm64@0.14.32: wanted {"os":"linux","arch":"arm64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-arm@0.14.32 (node_modules/esbuild-linux-arm):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-arm@0.14.32: wanted {"os":"linux","arch":"arm"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-linux-32@0.14.32 (node_modules/esbuild-linux-32):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-linux-32@0.14.32: wanted {"os":"linux","arch":"ia32"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-freebsd-arm64@0.14.32 (node_modules/esbuild-freebsd-arm64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-freebsd-arm64@0.14.32: wanted {"os":"freebsd","arch":"arm64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-freebsd-64@0.14.32 (node_modules/esbuild-freebsd-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-freebsd-64@0.14.32: wanted {"os":"freebsd","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-darwin-arm64@0.14.32 (node_modules/esbuild-darwin-arm64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-darwin-arm64@0.14.32: wanted {"os":"darwin","arch":"arm64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-darwin-64@0.14.32 (node_modules/esbuild-darwin-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-darwin-64@0.14.32: wanted {"os":"darwin","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-android-arm64@0.14.32 (node_modules/esbuild-android-arm64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-android-arm64@0.14.32: wanted {"os":"android","arch":"arm64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: esbuild-android-64@0.14.32 (node_modules/esbuild-android-64):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for esbuild-android-64@0.14.32: wanted {"os":"android","arch":"x64"} (current: {"os":"linux","arch":"x64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.4 (node_modules/cpu-features):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.4 install: `node buildcheck.js > buildcheck.gypi && node-gyp rebuild`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 2
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! ssh2@1.9.0 install: `node install.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the ssh2@1.9.0 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /root/.npm/_logs/2022-06-01T07_31_44_916Z-debug.log
J’ai vérifié directement dans les fichiers et le dossier /root/gladys/server/node_modules/ssh2/ n’existe pas. (j’ai recommencé plusieurs fois de 0 mais pareil)
Y-a-t’il un problème dans le script d’install ?
Merci d’avance :slight_smile:
Bizarre que tu sois root, normalement sous wsl tu créé un utilisateur.
En tout cas c’est l’origine de ton problème
Je suis root car je préfère toujours travailler en root :slight_smile:
J’essai avec l’utilisateur classique et je te dit :wink:
ça m’a l’air tout bon :slight_smile:
je poursuis l’installation merci :wink:
Salut.
Nouveau PC, je me suis reposé sur le problème que j’avais eu à mettre en place un environnement de DEV pour Gladys.
Même soucis que @Checconio sauf que j’étais bien avec mon compte utilisateur configuré à l’install de WSL. Puis j’ai du installer tous les modules en erreur lors de l’installe avec sudo npm install [MODULE] (serveur). Bien mettre sudo dans les appels, peut-être il faudrait bien le préciser dans la doc ?
En tout cas c’est bon, j’ai enfin l’environnement !
J’ai refait l’installe de l’environnement 2-3 fois :
  • Après le git clone, bien mettre son user owner du dossier « gladys » (Ne pas mettre un autre nom de dossier que « gladys », sinon certains fichiers se créent quand même dans le dossier gladys et l’instance ne peut pas fonctionner)
chown -R user gladys
Pour la partie server :
  • Se mettre owner sur le dossier node_module
    chown -R user:user node_modules/
  • Faire sudo npm install
    => l’installation de certains modules échouent
    => npm install sqlite3
    => faire la migration de db
    sudo npm run db-migrate:dev
    => Puis sudo npm install node-webcrypto-ossl
    => Puis sudo npm install node-broadlink
Le server démarre avec sudo npm start
Pour la partie front :
  • Faire npm install, l’installation de cypress échoue
    => sudo npm cypress
    => sudo npm install
Le front démarre normalement : sudo npm start
Questions :
  • A quoi sert Docker Desktop ?
  • Quel est le meilleur process à suivre vis-à-vis du repo Git pour au final proposer une PR.
    ** J’ai fait un fork de Gladys sur mon compte git.
    ** Créer une branche de mon repo pour faire un nouvelle intégration
    ** Configurer le repo / branche via VS Code
C’est le fait d’installer vos package en sudo qui casse tout, je vais revoir le tuto car ces étapes sont évidemment un contournement
