Mapping Zigbee2MQTT → Gladys for the outdoor siren NEO NAS-AB06B2
Following the discussion on Zigbee2MQTT → Gladys mapping for alarms, I am creating a specific topic for the NEO NAS-AB06B2 outdoor siren.
I am using this siren with Zigbee2MQTT. It is well recognized and reported in Gladys, but some features exposed by Zigbee2MQTT do not seem to be currently mapped to Gladys features.
The goal would be to be able to directly use the different functions of the siren in Gladys, especially from scenes, without having to manually send MQTT commands.
Equipment:
  • Brand: NEO
  • Model: NAS-AB06B2
  • Type: outdoor siren
  • Integration: Zigbee2MQTT
Zigbee2MQTT Documentation:
Original topic:
doc zigbee:
Model NAS-AB06B2
Vendor NEO
Description Outdoor solar alarm
Exposes alarm_state, alarm_switch, tamper_alarm_switch, tamper_alarm, alarm_melody, alarm_mode, alarm_time, charging, battery
Picture NEO NAS-AB06B2
Exposes
Alarm state (enum)
Alarm status.
Value can be found in the published state on the alarm_state property.
It’s not possible to read (/get) or write (/set) this value.
The possible values are: alarm_sound, alarm_light, alarm_sound_light, normal.
Alarm switch (binary)
Enable alarm.
Value can be found in the published state on the alarm_switch property.
It’s not possible to read (/get) this value.
To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"alarm_switch": NEW_VALUE}.
If value equals ON alarm switch is ON, if OFF OFF.
Tamper alarm switch (binary)
Enable tamper alarm.
Value can be found in the published state on the tamper_alarm_switch property.
To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"tamper_alarm_switch": NEW_VALUE}.
If value equals ON tamper alarm switch is ON, if OFF OFF.
Tamper alarm (binary)
Indicates whether the device is tampered.
Value can be found in the published state on the tamper_alarm property.
If value equals ON tamper alarm is ON, if OFF OFF.
Alarm melody (enum)
Alarm sound effect.
Value can be found in the published state on the alarm_melody property.
To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"alarm_melody": NEW_VALUE}.
The possible values are: melody_1, melody_2, melody_3.
Alarm mode (enum)
Alarm mode.
Value can be found in the published state on the alarm_mode property.
To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"alarm_mode": NEW_VALUE}.
The possible values are: alarm_sound, alarm_light, alarm_sound_light.
Alarm time (numeric)
Alarm duration in minutes.
Value can be found in the published state on the alarm_time property.
To write (/set) a value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"alarm_time": NEW_VALUE}.
The minimal value is 1 and the maximum value is 60.
The unit of this value is min.
Charging (binary)
Charging status.
Value can be found in the published state on the charging property.
If value equals true charging is ON, if false OFF.
Battery (numeric)
Remaining battery in %, can take up to 24 hours before reported.
Value can be found in the published state on the battery property.
The minimal value is 0 and the maximum value is 100.
The unit of this value is %.
Thank you :slightly_smiling_face:
Hi everyone!
This topic is now in development.
A PR has been opened to map the Zigbee2mqtt exposes of the solar outdoor siren NEO NAS-AB06B2:
Feel free to follow the PR, test (optional, especially for small requests) and give your feedback here if needed.
