Matterbridge Factory: shorter plugin names
is there a way to have understandable and especially short and concise plugin names?
I find the name of this plugin a bit complex:
Plugin name: matterbridge-ai-factory-freebox-player-delta-devialet-and-r-volution-freeboxos-player-api
This is a remark for all plugins, a simple « freebox » is largely sufficient in the title of the machine factory.
For Palazetti, it gives:
  • Name: matterbridge-ai-factory-po-le-palazzetti
The po-le is barely understandable :flushed_face: Just Palazetti would have been perfect.
Personally, I have a Freebox Pop and I would like to use such a plugin, but if I search and see Devialet or Révolution, I pass my way even though it should potentially be compatible :disappointed_face:
I moved it, indeed we can make it shorter! It also depends a lot on the title given in the GitHub ticket.
