My integrations are moving to Gladys 5.2 🎉
Gladys 5.2 is out, with the external integrations SDK in version 0.15.0. I’ve updated all my integrations (35) and took the opportunity to add the new features of 5.2 when they were useful.
:warning: Integrations marked « Gladys 5.2 required » only install and update on Gladys 5.2 or newer. Remember to update Gladys first.
Fuel Prices (v2.4.0)
Following your feedback (thanks @JPPUYB, @NineStars and @gaetanb76!):
  • The 3 full-width boxes: this is fixed on Gladys 5.2 (PR #3183). The price boxes are now arranged in a balanced grid: 3 prices remain side by side, even on a narrow card. No more « 2 half-width boxes + 1 full-width box ».
  • « Which house » becomes a list: no need to type the house name, you choose it from the list of Gladys houses. If you had already typed a name, it continues to work as long as you don’t choose anything.
  • A « Cheapest » card per house: new « House » setting on the card. You can have a card for the main house and one for the secondary residence, each with its stations around.
  • The color per fuel is not yet possible: it’s under discussion on Gladys.
  • Gladys 5.2 required.
New 5.2 Features in Other Integrations
Choose a house from a list
  • Apple Device Tracker (v2.3.0): choose the house from which the presence is measured. Gladys 5.2 required.
  • VigiEau (v3.4.0), Air Quality (v2.4.0), UV Index (v2.4.0), Pollen (v2.3.0): « Add my Gladys houses » allows you to add only one house, chosen from the list. Left empty, all houses are added as before. Gladys 5.2 required.
A form behind a widget button
  • Twinkly (v1.1.0): « Play… » button to choose a mode, a movie or an effect, with the brightness. Gladys 5.2 required.
  • LG ThinQ (v2.3.0): « Send a command » button directly from the widget. Gladys 5.2 required.
  • Dyson (v1.6.0): « Timer » button to set the automatic shutdown in minutes. Gladys 5.2 required.
  • Beatbot (v1.1.0): « Cleaning mode » button on the pool robot widget. Gladys 5.2 required.
  • Onkyo (v1.1.0): « Play a source » (input + volume) button when the zone is on standby. Gladys 5.2 required.
Fixes
  • HomeKit Controller (v1.0.4): an accessory added in Gladys receives its values immediately, even if they haven’t changed.
  • Twinkly, RFPlayer (v2.0.1), Wemo (v1.0.2): the version notes on GitHub were empty or messy, it’s fixed.
For all the others
SDK update to 0.15.0 and a bit of internal cleanup (less custom code, more shared SDK code). Nothing changes for you, and they still work with Gladys 5.1:
Integration Version
Broadlink 1.3.3
Daikin Cloud 4.3.3
Devmel 3.0.1
Ecovacs 1.3.1
Electricity Maps 2.2.5
Forecast.Solar 1.3.1
Home Connect 2.3.3
Host Supervision 2.2.2
Mammotion 1.4.1
Network UPS Tools (NUT) 2.2.2
Olvid 1.2.2
TV Guide 2.3.1
Proxmox 2.3.2
Proxmox Backup Server 2.5.1
Synology DSM 2.3.1
Team Tracker 1.0.2
Teleinfo 1.1.1
Lyon Public Transport 2.2.2
Veolia 1.0.3
Yoto 2.2.2
Z2M Devices Monitor 2.2.2
Good to know
  • In the configuration of an integration, if you choose a house and then want to go back to « empty », Gladys refuses to save. Instead, choose the desired house from the list.
As usual, don’t hesitate to share your feedback here, with a screenshot if possible :slightly_smiling_face:
New series of updates: all my integrations (38) now speak German and Spanish, in addition to French and English. These are the four languages of the Gladys interface.
:information_source: No new version of Gladys is required: each integration requires the same minimum version as before.
What is translated
  • The configuration screen: labels, descriptions, help, choice lists and action buttons.
  • Messages: connection status, button responses, badges, widget notifications.
  • Widgets, triggers and scene actions: all displayed text.
  • Documentation: each integration now has a German page and a Spanish page, in addition to French and English.
Gladys displays each text in the language of your account. For another language, it’s English.
Device names
  • Air Quality, Pollens, UV Index, Home Connect, Mammotion, Team Tracker: the language setting for device names now offers German and Spanish. The default value does not change.
  • Dyson: the language of the names follows the country of the Dyson account (Germany, Austria → German; Spain, Latin America → Spanish).
  • Olvid: Gladys responds in the language of the Gladys user linked to the contact.
:warning: An already created device keeps its names. The new language only applies to devices added afterwards: this is the normal operation of Gladys.
By the way
  • Documentation: the English and German docs now use the exact names of the Gladys screens (« Discover », « Add to Gladys », « Dashboard → Edit → New widget »…). I took the opportunity to correct a few paths that did not exist, such as « Settings → Energy » (it’s the Energy Tracking integration).
  • Verisure: in Spanish, the alarm uses Verisure’s words (« conectar / desconectar »).
  • Faikout: correction of the publication script, which could have misplaced the change log.
  • Fuel Prices, Synology DSM and Lyon Public Transport: a few English words that were lingering in the French messages are corrected.
  • Error messages in red under configuration buttons remain in English and French: Gladys does not transmit the user’s language for these errors.
Versions
  • Apple Device Tracker: 2.4.0
  • Beatbot: 1.2.0
  • Broadlink: 1.4.0
  • Daikin Cloud: 4.4.0
  • Devmel: 3.1.0
  • Dyson: 1.7.0
  • Ecovacs: 1.4.0
  • Electricity Maps: 2.3.0
  • Faikout: 1.1.0
  • Forecast.Solar: 1.4.0
  • Home Connect: 2.4.0
  • HomeKit Controller: 1.1.0
  • UV Index: 2.5.0
  • LG ThinQ: 2.4.0
  • Mammotion: 1.5.0
  • Network UPS Tools (NUT): 2.3.0
  • Olvid: 1.3.0
  • Onkyo: 1.2.0
  • Pollens: 2.4.0
  • Fuel Prices: 2.5.0
  • TV Guide: 2.4.0
  • Proxmox: 2.4.0
  • Proxmox Backup Server: 2.6.0
  • Air Quality: 2.5.0
  • RFPlayer: 2.1.0
  • Host Supervision: 2.3.0
  • Synology DSM: 2.4.0
  • Team Tracker: 1.1.0
  • Teleinfo: 1.2.0
  • Lyon Public Transport: 2.3.0
  • Twinkly: 1.2.0
  • Veolia: 1.1.0
  • Verisure: 1.1.0
  • VigiEau: 3.5.0
  • Wemo: 1.1.0
  • Xbox: 1.1.0
  • Yoto: 2.3.0
  • Z2M Devices Monitor: 2.3.0
Call to German and Spanish speakers
The translations have been reviewed, but nothing beats a native eye. If a sentence sounds wrong or if a technical term is not correct, say it here and I will correct it.
As usual, do not hesitate to report your feedback here, with a screenshot if possible :slightly_smiling_face:
It’s perfect for the balanced grid, the visual is much more coherent, thank you :slight_smile:
