My thoughts on the Dreo integration
What works well:
Thank you again for this impressive work on the Gladys Assistant integrations!
Feedback on my Dreo devices. I have 3 heating devices: 2 that I use as supplementary heating in an unheated basement and 1 bathroom heater (also controllable by remote control).
All three are integrated into the Dreo cloud application. The integration with Gladys works very well and without delay. What I still need to do is to be able to schedule the operating hours in Gladys identical to those I have scheduled in the Dreo app. To do this, I will have to carefully look at what has been done in the “Thermostat” developments. At first glance, it’s very similar, with daily scheduling and several possible periods in the same day. To note the differences, there may be a few “pre-selections” in the Dreo app, such as the choice of weekdays or weekend. The day is visually different instead of being on a line, it is represented by a watch dial from 0 h to 24 h.
What could be improved:
My first Dreo device, which I installed in the basement, is a connected Dreo dehumidifier model DR-HDH002S (20L/day).
It is well detected on my Dreo cloud account, but it is logically ignored for the moment:
[INFO] [dreo] Connected to the Dreo cloud: 3 device(s) handled, 1 not supported
I post this request here to keep a record in case an update of the Dreo integration is planned one day (absolutely no urgency of course!).
Technical information to facilitate the addition:
Model reference: DR-HDH002S
Category: Dehumidifier
Control functions:
  • On/Off switch,
  • Fan speed (3 levels low medium and high), as on the heaters,
  • Setting the target humidity,
  • Ambient humidity sensor,
  • Modes (Auto, Comfort, Continuous, Clothes Drying),
  • Child safety
  • Screen off.
There are 2 alerts specific to the dehumidifier (in addition to the classic functions):
  • Full water tank indicator: sends an alert and automatically turns off the device. It’s better to avoid flooding :wink: In my opinion, this is one of the most important functions because the device stops and you have to intervene to empty the tank.
  • Filter cleaning indicator (every 600 h): sends a maintenance alert without stopping the device (the cleaning instruction is set by default to 600 h but it is modifiable).
Technical base: The data structures of this model have already been documented on hass-dreo (Dehumidifiers | DR-HDH)
I remain of course available if you need additional logs or tests when you have a moment.
Sent from Gladys v5.3.4
@pjrlyon thanks for this very complete feedback on DREO, it’s a pleasure :slightly_smiling_face: The DR-HDH002S dehumidifier is rated: with your info and the hass-dreo documentation, I’ll add it in a next version (on/off, speed, target and measured humidity, modes, and especially the full bucket alert). I’ll let you know here for testing.
