New Gladys freeze issue
Gladys has been spinning in circles for a while now :frowning:
The issue: I added some devices discovered with the Somfy integration, then I modified the rooms and after 3 or 4 saves, it started spinning.
Here are the logs:
2026-11-19T20:50:30+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
    at readStream (/src/server/node_modules/raw-body/index.js:185:17)
    at getRawBody (/src/server/node_modules/raw-body/index.js:116:12)
    at read (/src/server/node_modules/body-parser/lib/read.js:80:3)
    at jsonParser (/src/server/node_modules/body-parser/lib/types/json.js:142:5)
    at integrationHostJsonBodyMiddleware (/src/server/api/middlewares/jsonBodyMiddleware.js:89:10)
    at Layer.handle [as handle_request] (/src/server/node_modules/express/lib/router/layer.js:95:5)
    at next (/src/server/node_modules/express/lib/router/route.js:149:13)
    at /src/server/api/middlewares/externalIntegrationAuthMiddleware.js:30:5 {
  type: 'stream.not.readable'
2026-11-19T20:50:39+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:50:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:50:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:50:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:50:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:50:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:50:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:50:54+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:51:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:24+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:25+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:49+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:54+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:51:55+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:52:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:37+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:39+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:45+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:53:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:53:49+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:54:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:23+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:28+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:4:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:45+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:55:46+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:55:47+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:55:48+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:55:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:55:52+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:55:54+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:04+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:4:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:27+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:56:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:43+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:56:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:56:55+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:4:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:01+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:4:0:multilevel_sensor:illuminance" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:07+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:27+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:72:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:34+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:4:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:37+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:51+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:52+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:57:57+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:25+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:27+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:31+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T20:58:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:58:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:27+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:28+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T20:59:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:01+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:72:0:multilevel_sensor:power" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:40+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:00:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:03+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:01:11+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:01:49+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:01:50+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:01:51+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:02:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:25+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:27+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:27+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:02:30+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:31+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:02:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:10+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:14+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:03:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:37+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:39+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:49+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:03:49+0100<warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:04:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:27+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:04:37+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:39+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:44+0100<info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:04:47+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:multilevel_sensor:illuminance" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:01+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:05:03+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:05:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:05:49+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:00+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:01+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:25+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:06:26+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:06:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:42+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:06:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:57+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:06:58+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:1:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:46+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:8:2:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:49+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:07:51+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:07+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:08:08+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:08:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:16+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:18+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:08:19+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:08:20+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:multilevel_sensor:illuminance" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:45+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:08:55+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:57+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:08:58+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:18+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:21+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:multilevel_sensor:illuminance" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:35+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:10:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:48+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:49+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:67:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:09:58+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:01+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:multilevel_sensor:illuminance" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:02+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
    at readStream (/src/server/node_modules/raw-body/index.js:185:17)
    at getRawBody (/src/server/node_modules/raw-body/index.js:116:12)
    at read (/src/server/node_modules/body-parser/lib/read.js:80:3)
    at jsonParser (/src/server/node_modules/body-parser/lib/types/json.js:142:5)
    at integrationHostJsonBodyMiddleware (/src/server/api/middlewares/jsonBodyMiddleware.js:89:10)
    at Layer.handle [as handle_request] (/src/server/node_modules/express/lib/router/layer.js:95:5)
    at next (/src/server/node_modules/express/lib/router/route.js:149:13)
    at /src/server/api/middlewares/externalIntegrationAuthMiddleware.js:30:5 {
  type: 'stream.not.readable'
2026-11-19T21:10:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:14+0100 <warn> errorMiddleware.js:83 (errorMiddleware) InternalServerError: stream is not readable
2026-11-19T21:10:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:29+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:41:0:binary_sensor:general_purpose" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:42+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:43+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:44+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:45+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:10:58+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:11:00+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:25:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:11:12+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_kwh_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:11:13+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_w_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:11:14+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_v_consumed" not found (or not added to Gladys), skipping state update.
2026-11-19T21:11:15+0100 <info> device.newStateEvent.js:18 (DeviceManager.newStateEvent) DeviceFeature "zwavejs-ui:9:0:meter:value:electric_a_consumed" not found (or not added to Gladys), skipping state update.
I see a lot of zwave-js, is that the problem? @Sescandell
I don’t think it’s the Tahoma SOmfy plugin because I’ve already had these freezing issues with many other plugins and always when I modified the device’s room.
@cicoub13 @pierre-gilles any ideas?
I’m also looking into it with Claude to see what he can find.
