PC-Pilot — Control your PC from Gladys
Hello everyone!
I’ve developed a small tool to control a Windows or Linux PC directly from Gladys scenes: \\PC-Pilot\\.
It runs as a tray icon on your PC and exposes a local REST API that Gladys can call via HTTP requests.
## What does it do?
\- \\Shut down\\, \\restart\\, \\sleep\\, \\hibernate\\ or \\lock\\ your PC
\- \\Start or stop applications\\ (Firefox, VLC, etc.)
\- \\Run custom commands\\ (backup scripts, etc.)
## How does it work
1\. Install PC-Pilot on the PC to control
2\. Add your Gladys IP to the allowed IPs (from the tray menu, no need to edit a file)
3\. Copy the API token from the tray menu
4\. Create a Gladys scene with an HTTP request action
Example to lock your PC:
| Champ | Valeur |
| Méthode | \POST\\ |
| URL | \http://\u003cip-du-pc\u003e:7042/api/v1/system/lock\\ |
| Header | \Authorization\\ = \Bearer \u003cyour-token\u003e\\ |
| Header | \Content-Type\\ = \application/json\\ |
| Body | \{}\\ |
\u003e Don’t forget the \{}\\ in the body — Gladys requires it even when the API doesn’t need it.
## Use cases
\- « Turn off the PC » by voice command
\- Lock the PC when leaving the house
\- Launch an application when arriving home
\- Run a scheduled backup
## Security
Everything stays on your local network. Token authentication, IP whitelist, rate limiting, no shell injection possible.
## Links
\- \\GitHub\\ : GitHub - david-digitis/pc-pilot: REST service to control a Windows/Linux PC from a home automation system (Gladys Assistant). Electron tray + Fastify API. · GitHub
\- \\Download (Windows)\\ : Releases · david-digitis/pc-pilot · GitHub
Your feedback is welcome!
Linux build available. Tested on Fedora / Wayland
Thanks, nice little app :slight_smile:
Usage - Automatic standby when I leave the house or when I go to bed
With pleasure!
Thanks @David-Digitis , you’re very productive !
