Plus de retour de node-red dans Gladys
Je viens de me rendre compte que plus aucune valeur ne remontait de node-red.
C’est un node-red créé hors Gladys il y a 2 ans et qui fonctionne très bien.
Je viens de redémarrer le conteneur mais cela n’a rien changé.
Sur les graphiques, les dernières valeurs datent du 28 novembre vers 17h40.
les logs de node-red:
Welcome to Node-RED
1 Dec 11:55:45 - [info] Node-RED version: v3.0.2
1 Dec 11:55:45 - [info] Node.js  version: v16.16.0
1 Dec 11:55:45 - [info] Linux 6.8.0-48-generic x64 LE
1 Dec 11:55:45 - [info] Loading palette nodes
1 Dec 11:55:48 - [info] Dashboard version 3.2.3 started at /ui
1 Dec 11:55:49 - [warn] ------------------------------------------------------
1 Dec 11:55:49 - [warn] [node-red-node-rbe/rbe] 'rbe' already registered by module node-red
1 Dec 11:55:49 - [info] Settings file  : /data/settings.js
1 Dec 11:55:49 - [info] Context store  : 'default' [module=memory]
1 Dec 11:55:49 - [info] User directory : /data
1 Dec 11:55:49 - [warn] Projects disabled : editorTheme.projects.enabled=false
1 Dec 11:55:49 - [info] Flows file     : /data/flows.json
1 Dec 11:55:49 - [info] Server now running at http://127.0.0.1:1880/
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
1 Dec 11:55:49 - [info] Starting flows
1 Dec 11:55:49 - [info] Started flows
1 Dec 11:55:49 - [info] [serialconfig:9f5c1de0b87d7daa] serial port /dev/ttyACM0 opened at 57600 baud 8N1
1 Dec 11:55:49 - [info] [zigbee2mqtt-server:Gladys] MQTT Connected
1 Dec 11:55:49 - [info] [mqtt-broker:Gladys] Connected to broker: mqtt://192.168.xx.xxx
1 Dec 11:55:49 - [info] [zigbee2mqtt-server:Gladys] MQTT Subscribed to: "zigbee2mqtt/#
1 Dec 12:00:29 - [info] Stopping modified nodes
1 Dec 12:00:29 - [info] Stopped modified nodes
1 Dec 12:00:29 - [info] Updated flows
1 Dec 12:00:29 - [info] Starting modified nodes
1 Dec 12:00:29 - [info] Started modified nodes
1 Dec 12:00:29 - [info] [mqtt-broker:Gladys] Connected to broker: mqtt://192.168.xx.xxx
Dans MQTT Explorer il y a bien toutes les valeurs.
Des idées ?
EDIT :
Le broker MQTT était arrêté dans Gladys…
Le container MQTT était stoppé, ou juste Gladys était déconnecté du broker ?
ça peut rejoindre le souci de déconnexion MQTT que certains ont (@Terdious par exemple)
Le slider Broker dans un connecteur Docker était ok.
Il y a avait écrit « Déconnecté du broker MQTT »
j’ai cliqué sur Sauvegarder la configuration pour que ça revienne.
Ok c’est effectivement le même souci que @Terdious
De mon côté, je n’arrive pas à reproduire, mais @Terdious a souvent le souci et il a dit qu’il investiguerait :
