The georisque integration tells me that I don’t have a SEVESO site, even though the georisque website clearly indicates that I do
@guim31 I’m sending you the URL of the georisque site with my town in a private message ![]()
Thanks
Thanks
Thanks for the feedback @prohand!
Good catch: the Géorisques API no longer accepts the old Seveso status codes; it was always returning 0, both for the municipality and the 5 km radius. This has been fixed in version 1.0.2 (verified in Feyzin: 3 Seveso sites returned instead of 0).
You can update from Gladys, and let me know if your municipality is now showing up correctly ![]()
Thanks, that’s good ![]()
Three houses, three devices but it’s the content of the active configuration that appears everywhere.
Did I miss something?
Hi @JPPUYB,
No, you didn’t miss anything: today, the integration follows one place at a time, the configured one. When you change it, a new device appears for the new town, but only the one from the configured location is updated, and the widget always shows that location. Devices from other towns keep their last values: you can delete them.
Tracking multiple houses at the same time (one device and one widget per house), I’ll note that, I’ll look into it ![]()
All three update simultaneously based on the reconfigured value…
Thanks @JPPUYB, I found it: what moved together were very likely your three widgets. They had no settings, so they all displayed the location from the configuration.
The 1.1.0 (update from Gladys) now follows multiple homes:
Two homes in the same municipality share the same device. Let me know how it works for you ![]()
Configuration:
Position = My home in Gladys
Home field = empty
Address = empty
INSEE code of the municipality = empty
An error occurred while saving the configuration.
Thanks @JPPUYB, and sorry about that! I found the issue: it’s not the integration, it’s Gladys herself that refuses to save the « Maison » field once it’s empty (I reported it to the Gladys team).
To work around this, the 1.2.0 (update from Gladys) adds a position « All my houses in Gladys » : choose it, save, and all your houses that have a position are tracked, regardless of the Maison field. In each widget, the Maison setting chooses the one to display.
That’s good for the three houses.
I had checked the addresses before…
Great!
