Sorry to dig up this topic, I don’t know if this is the right place.
A few questions about Matter integration.
Is it possible to find Matter in the list of installed integrations?
I have a lot of Matter over Thread devices from the IKEA range, including Grillplats outlets. I constantly get messages suggesting updates, which appear even if I perform these fake updates. Is this a problem on my end?
In the “energy consumption” widget, the names of the outlets are replaced by other names, which can quickly become complicated
Thanks for your feedback, you’re in the right place I’ll address your three questions.
1. Matter in the list of installed integrations
The “Installed” tab only lists community integrations, those that are installed separately on the instance. Matter is part of Gladys (like Zigbee2mqtt or Philips Hue), so it will never appear in this tab. To find it quickly, you can add it to your favorites with the star: it will be in the “Favorites” tab.
2. The recurring update messages
This isn’t an issue on your end. Gladys displays “This device already exists in Gladys with new features…” when what the device announces in Matter no longer exactly matches what is recorded in Gladys.
On an energy-measuring plug, certain features (voltage, current) are only added if the plug responds when Gladys queries it. In Thread, this doesn’t always work. As a result, the list of features changes from one scan to another, and the update suggestion comes back even right after you’ve done it.
This doesn’t affect the operation of your plugs, you can ignore these messages for now. To confirm and fix this, you could send me:
a screenshot of a card that suggests the update, with the list of displayed features;
a screenshot of the same plug in the tab of Matter devices already added to Gladys.
3. The names in the “Energy Consumption” widget
You found two bugs, thanks!
In the widget editing : once a plug is selected, Gladys displays its technical identifier (matter-16-2-145-energy-cost) instead of its name. This bug has existed since the creation of the widget and affects all integrations, not just Matter. The number after matter- is the Matter node number of the plug, which can help you keep track in the meantime. GladysAssistant/Gladys#3376
In the chart : the legend is built from the names of the features, without the name of the device. In Matter, these names are technical and identical for all plugs (« ElectricalEnergyMeasurement - 2 (Energy)… »). Gladys therefore numbers them (1), (2), (3)… and we no longer know which plug is which. GladysAssistant/Gladys#3377
We’ll fix these two points, you can follow the progress on the GitHub tickets.
Here is a screenshot of 4 proposed updates, the problem being that the outlets are not distinguishable since they are all identified by their name “Grillplats”.
Another oddity, I have the impression that after changing the state of the on/off switch, the outlets are again “to be added to Gladys” (even though they are still usable as usual). Currently, my 5 Grillplats appear “add to Gladys” while they are all turned on
My first explanation was wrong. On your screenshots, the voltage and current are indeed present on all 4 outlets. So it’s not a feature that appears and then disappears from one scan to another. There’s something else going on, and I’m still trying to figure out what.
In the meantime, don’t click on « Update ». Looking at the code, I saw that this button replaces the device name in Gladys with the generic name announced in Matter (« IKEA of Sweden (GRILLPLATS Plug) 2 »). If you had renamed your outlets, you’ve probably lost their names like this. Your outlets are working normally, so you can simply ignore these cards for now.
To move forward, you could send me:
The JSON file of your Matter nodes: in the Matter integration, « Settings » tab, « Download Matter Nodes as JSON » button. It doesn’t contain sensitive information, you can post it here.
A screenshot of your Grillplats outlets in the list of devices already added to Gladys, at the bottom of the « Devices » page of the Matter integration.
One more detail: when you talk about changing the state of the on/off switch, are you turning the outlet on or off (from Gladys or with the physical button), or the activation of the Matter integration in its settings?
Thanks Damien, your screenshot and file helped me find the problem!
Why updates keep coming back
Every 30 minutes, Gladys calculates the consumption of each outlet. To know where it stands, it records the date of the last calculation on the device: that’s the unnamed line with a date you see in your screenshot. The Matter integration compares the device recorded in Gladys with the one the outlet announces. This parameter only exists on Gladys’s side, so Gladys thinks the device has changed and suggests updating it.
When you click on “Update”, this parameter is deleted, then recreated at the next calculation. The suggestion therefore comes back at the latest 30 minutes later. That’s also why only the “consumption” parts of your outlets are affected, and not the on/off parts.
In the meantime, you can safely ignore these cards, everything works. Just avoid clicking on “Update” or “Add to Gladys” for your already added outlets: it replaces the names you gave them with the generic name “IKEA of Sweden (GRILLPLATS Plug) 2”.
