Hi everyone!
Gladys Assistant 5.3.4 is out ![]()
Last week, 5.3.3 rebuilt the dashboard and the scenes for the phone. This release finishes the job: the rest of Gladys gets its phone layout, from the sign-in page to the energy contract wizard, by way of every device page. On a computer, the layouts stay the same.
All of Gladys, on your phone
- the page of a device: name and room first, then one row per feature that opens in a panel;
- the “Devices” and “Discovery” tabs of Matter, MQTT, Bluetooth, AirPlay, LAN Manager, Enedis, Thermostat, RTSP cameras, Zigbee2MQTT and every external integration: one row per device instead of a stack of desktop cards;
- houses and rooms, settings, the energy contract wizard and map zones (tap to place a zone, drag to move or resize it);
- the sign-in page and the locked keypad of wall tablets, with big keys sized to the screen;
- nothing is deleted on a single tap, and unsaved changes are never lost silently, the phone’s “back” gesture included.
Zigbee2MQTT: a setup wizard and a dashboard
- a 4-step wizard for the first installation: Gladys shows the dongle it detected, installs Zigbee2MQTT phase by phase, and explains failures in plain words;
- the installation runs in the background, and it’s faster: images downloaded in parallel, the MQTT broker started only once;
- a dashboard replaces the old setup page, and “Stop” is remembered across restarts;
- the dongle is found again wherever it is plugged, and Zigbee2MQTT restarts on its own when you plug it back;
- a new device shows its values as soon as you add it (reported here).
Gladys tells you when something goes wrong
- a command that fails is announced, and the switch goes back to the real state;
- a “Gladys is unreachable” notice shows up when the connection is lost, and dashboards reload themselves once Gladys is back;
- the live connection keeps reconnecting until Gladys is back: no more wall tablet silently frozen after an update;
- the sign-in page tells a wrong password apart from a server that does not answer;
- the infinite spinner on iPhone with Gladys Plus is fixed (this topic).
Fewer accidental deletions
On a computer, deleting a device now asks first in 22 integrations, and a deleted step of a scene can be restored with “Undo”.
And also
- wall tablets: a URL sets up tablet mode and full screen without going through the menu (as requested here);
- the AI chat understands answers to messages sent by your scenes (this topic);
- the native Nuki integration is deprecated in favor of the community Gladys-Nuki integration, with a “Migrate” button;
- the thermostat dial stays within the range of the thermostat;
- Gladys could freeze for minutes after saving a device: fixed (this topic);
- a scene blocked on an offline Matter device can be stopped again (this topic);
- and a bunch of fixes (MQTT wildcards, Home Assistant payloads, cameras, external integrations…).
All the details, with screenshots, are in the blog post: Gladys Assistant 5.3.4: all of Gladys on your phone, and a new Zigbee2MQTT setup | Gladys Assistant
As always, Gladys updates automatically within 24 hours if you use Watchtower, otherwise you can do it in one click from the settings.
A big thank you to @cicoub13, @Will_71, @mutmut, @spenceur and Zagg for their contributions to this release!
If you set up Zigbee2MQTT with the new wizard, or try Gladys on your phone, let us know how it goes below ![]()
