Gladys Assistant 5.0.1: Already some fixes!
Hello everyone :waving_hand:
Gladys Assistant 5.0.1 has just been released! This is a bugfix version, published right after 5.0.0: no major new features, mostly fixes for the small issues you reported today on the forum and on GitHub. Thanks for all your feedback :folded_hands:
:artist_palette: Interface & dashboard
  • The Horizon theme is now painted on a fixed layer: no more dashboard scrolling slowdowns.
  • Dashboard cards no longer open a horizontal scrollbar.
  • Scene names that are too long now wrap correctly in the « Scenes » widget.
  • Weather icons, too small and washed out in light theme, are fixed.
  • Missing arrows are back on all dropdown lists, and sort selectors are finally readable as proper controls.
  • A dropdown menu no longer closes itself right after opening.
  • The setpoint selector (heating) no longer truncates decimal values.
:mobile_phone: Mobile
  • The dashboard « … » menu stays well within the screen on mobile.
  • The mobile dock navigation bar is now scrollable when you have many dashboards (following your forum feedback :wink:).
:clapper_board: Scenes
  • Variable renumbering is propagated when you delete an action inside a group.
  • An error in a single widget no longer freezes the entire application, and the editor buttons remain accessible on screen.
  • The « Speak on a speaker » action now accepts a calculated volume, and its volume setting has the new Horizon slider.
:electric_plug: Integrations
  • Zigbee2mqtt: explicit error message when connection to an external MQTT broker fails due to bad credentials.
  • Free Mobile: the built-in integration is marked as soon to be deprecated.
  • External integrations start again on kernels without « CFS bandwidth control ».
  • Maps: CARTO map backgrounds are replaced by OpenFreeMap vector tiles.
  • Gladys Plus: a warning appears if your local instance is behind the hosted interface.
:up_arrow: Update
The update is done as usual from Settings → System, or automatically if you have enabled automatic updates.
:page_facing_up: Full change details: Release v5.0.1 · GladysAssistant/Gladys · GitHub
Don’t hesitate to keep reporting what you find! :rocket:
2 messages were split to a new topic: Question about the MQTT in scenes
A message was merged into an existing topic: Question about the MQTT in scenes
