**I want to use a lamp’s blinking, but without the timer coming into play **. That is to say, I will start the blinking and I am the one who decides when to stop it. Currently when you start a lamp’s blinking, you have to set a timer and it is that timer that stops the lamp. So indeed when you turn the lamp off the lamp turns off, but if you turn it back
Related topics
| Topic | Replies | Views | Activity | |
| Clignotement des eclairages , prises | 6 | 100 | January 27, 2025 | |
| Demande d'ajout d'un compte à rebours pour les lampes et prises | 6 | 411 | January 25, 2023 | |
| Utiliser le système de temps avec les capteurs de présence | 2 | 670 | April 4, 2022 | |
| Pouvoir régler l'intensité de la lumière dans une scene | 1 | 943 | July 6, 2021 | |
| [SCENES] Scène à conditions ET actions multiples (type toggle) | 10 | 770 | April 25, 2024 |
