Non-existent energy monitoring feedback
I’m having a small issue with energy monitoring. At first glance, everything seems to be working correctly, but I have two devices for which the data is not being reported.
3 out of 4 are reporting
same, 3 out of 4 are reporting
the one that isn’t working
the one that is working
I don’t really understand why, as the other devices seem to be communicating fine. Does anyone have any idea what could be causing this issue?
Bizarre indeed :confused:
Have you checked if the consumption of those that weren’t working had a history with a graph of their own consumption and the 30-minute consumption?
And have you tried a complete recalculation of the energy tracking?
Indeed, no history even though the radiator is heating
You should check in z2m if your devices are correctly reporting power and energy, there might have been an issue on that side.
I already added the two screenshots of the affected devices in my previous post, but honestly, I don’t see anything abnormal in their configuration.
Following your advice, I went into Zigbee2MQTT and clicked the yellow button. We’ll wait a few hours to see if the data starts coming back.
