Dashboards
I arrived on Gladys a few weeks ago, version 5 hadn’t been released yet and as far as I remember, there were about thirty integrations.
Today, it’s a whole different story, there are so many integrations, all as interesting as each other (a huge bravo to the contributors). However, I can’t seem to settle down and structure my dashboards. Pierre-Gilles let me know that the community can share their dashboards. You’ll have understood, I’m happy to take your work and I thank you in advance.
I am in the same situation as JKBS64, is it possible to have examples of dashboards?
If we put a widget on the main dashboard and click on it, does it open a 2nd dashboard with more details?
Thanks again to all contributors
@JKBS64 @Pat
Hi you two, I’m also a complete beginner, but I did it like this:
  1. First, I created a dashboard for each category and assigned a separate background color to it for clarity.
    These dashboards automatically create the title list displayed at the top. A click opens the dashboard.
    You create a dashboard very easily. Click on the pencil with the paper in the top right corner, then a horizontal list of the existing dashboards will be displayed in the upper area, next to it a plus, a click and there is a new dashboard.
Here for example my start dashboard:
A standard dashboard has three columns (more on that in a moment), and you can then add to each column by clicking « Add » what is available. It will be displayed. For example, I have stored all the necessary immediate information, more or less without control. It is a pure information board, but as the start dashboard also immediately available.
Here are some more dashboards:
Here is my weather dashboard with finely granulated information, I am an allergy sufferer, so sufficient information about the weather, rain situation, pollen and air quality.
Almost at the end the statistics, another dashboard:
There I have simply from left to right the energy monitoring, what is drawn from the grid, what the PV produces, what is the total consumption and so on and so forth.
Now to the columns. By default, you are offered three columns. You can delete or add them within the respective column, but these columns also control the display on your much smaller smartphone.
There the order is:
First comes the selected dashboard, then all devices, widgets, etc. of the first column are displayed, below comes column 2 and at the very end column 3.
This gives you the opportunity to quickly access your information on a smartphone without much scrolling. That is, high priority rather in column 1, additional information, etc. rather in column 3.
Greetings
Tom
Thanks so much @ruegerth for your feedback. Your tables are inspiring and reassure me about what I’ve put in place. I think the key is not to rush and to carefully consider the needs while setting a goal to achieve. Keep up the good work on Gladys.
Thanks for this example, it gives ideas!
