It would make sense to be able to use the “energy consumption” widget for gas, as we do for electricity
Gazpar and Energy Monitoring
Postulate: What is the difference between electricity and Gazpar?
They are kW, of course just one figure per day for Gazpar.
The GRDF customer space plans to add meters, same principle as ENEDIS. The integration only plans for one. Personally, one is enough for me, but for other users it might be completely different.
The device created by the integration to be named with the PCE number, in other words the equivalent of the PDL at ENEDIS:
A priori, the temperature is in the customer space, but I haven’t retrieved it: why? ….
The integration documentation states that the history is only provided at the first connection ….
However, some time ago, about a week, I had the following screen:
Meter index (consumption) and meter index () cost have disappeared with their history …
For billing, in my case with Total, I have a green contract reviewed each year, revised as of 19/10/2026.
On the customer bill, there is: the subscription, consumption in m3 and in kWh, conversion rate, price per kWh and of course other taxes …. I therefore created a local contract and obtained two graphs: one for consumption and one for cost given that:
Gazpar kWh are already converted: the meter measures m³, and GRDF converts them to kWh with the conversion coefficient of the municipality. As suppliers bill gas in kWh, you just need to enter your price per kWh
Gazpar data (m³, kWh) are recorded as standard sensor values. They can be displayed in a graphical widget on a dashboard, but Gladys does not calculate the cost.
Pierre-Gilles Advice and Future:
When Total changes the gas price, do not modify the old contract. Rather, create a new contract that starts on the date of the change. That way, past months keep the old price.
Officially, energy monitoring only manages electricity for now: the model includes gas, but it is not finished. In practice, a gas contract is recorded as an electricity contract, the assistant talks about an “electric meter” and the catalog does not offer any gas contract model. It works, but it is a workaround, not yet a feature designed for it.
Finally, are the differences in the device and the absence of temperature due to an evolution of the GRDF interface?
Observation regarding temperature:
If I switch to modification mode:
Currently, there is no consumption, and that is indeed the case. However, I have a temperature value in modification mode…… Why isn’t a recent value displayed in the simple view?
Another observation: in the device’s full display, I don’t have a temperature value under “recent”?
