Widgets and integrations
I installed the Ariston.net integration but some functions were missing. I mentioned this to @guim31 (thanks for his quick response!!!) and I noticed there are two types of widgets (Gladys and Integrations).
I therefore need to create a new widget on my dashboard (+ new widget-gladys-devices) to find the missing functions. This splits the integration into two.
Same observation with the SOUNDTOUCH integration, which works perfectly after updating with ST Reborn (thanks again @guim31).
In any case, I no longer need to use HA and Matterbridge as I can use Gladys at 100%.
Well done to you
Thanks @Fabrice :raising_hands: Glad everything is working for you!
