Creating a thermostat
Good evening,
All these functions are incredible and cover many devices.
I have been trying for some time to create a dashboard specific to the thermostat and/or a scene that allows me to control two radiators in the same room but I can’t manage it. As usual, I would need some advice.
Thanks in advance for your feedback
Hi @Jluc,
Thanks for your message :slightly_smiling_face:
To help you, I need a bit more detail. Right now, I don’t quite see what you’re trying to do or what’s not working.
Could you specify:
  1. Your radiators: which model, and how they are connected to Gladys (Zigbee2mqtt, Tuya, Netatmo, MQTT…)? Are they thermostatic radiator valves, smart thermostats, or radiators connected to a relay or smart plug?
  2. What Gladys sees from these radiators: which features appear on the device page (temperature setpoint, mode, thermostat wire, simple switch…)? A screenshot would be ideal.
  3. What you want to achieve concretely: for example, “set both radiators to 20 °C at the same time from the dashboard”, “switch them to eco mode at night and comfort mode in the morning”, “turn off the heating when the window is open”…
  4. What you have already tried, and what happens: which widget you added to the dashboard, which scene you created (trigger and actions), and what’s not working. For example: the radiator does not appear in the list, the command does not go through, or there is an error message. Screenshots help a lot here too.
  5. Your version of Gladys.
A tip: have you seen the “Thermostat” integration (in Integrations)? It allows you to create virtual thermostats or program existing thermostats and radiators with schedules. Radiators with thermostat wires are managed since 5.3.1. This might be what you’re looking for, but first tell us what hardware you have, and we’ll guide you to the right solution.
Hi @pierre-gilles,
Thank you for your feedback and also for all the updates to Gladys (regular updates to V 5.3.3). Like some others, I’m even overwhelmed by the new features, some of which are beyond my level.
I use Moes BRT 100 TRV thermostatic valves in zigbee2mqtt, which I manage directly with scenes, with data visualization on graphs in Gladys. They expose many functions: Eco mode, Eco temperature, Max temperature, min temperature, valve opening and closing with %, the window opening function (I’ve never managed to get it to work), the temperature measured at the head, the setpoint temperature, calibration, the display of heating or rest mode.
The problem I’m encountering is that the temperature at the thermostatic valve level does not match that of the room because the radiator is under the window. The thermostat function that I tried to use without success interests me because it allows you to obtain a defined temperature in the room where I have a thermometer in a central position.
On the dashboard, I also have a temperature setting available for comfort.
So it’s case 3 that you describe that matches my need. I have two scenes activated at the moment and several others that I use depending on the presences and the times of the day.
The devices and data are correctly reported in Gladys.
Hi @Jluc, you might be able to give us more details about what isn’t working with the thermostat function and we can guide you
Thanks @Will_71 for looking into my issue. I’m going to cancel everything and start from scratch and will come back, hopefully to announce that it works.
You can also give us the details if you’re having issues so we can help you
Good evening @Will_71,
As discussed earlier, I started from scratch with the documentation at hand. I removed the scenes I was using before as well as the associated dashboard.
The time slots with the different settings of the integration activated normally throughout the day and the thermostatic heads followed the commands from the thermostat regulation.
In the end, everything works very well, so thank you for your follow-up, as well as that of @pierre-gilles.
Excellent news @Jluc!
Can we mark this topic as resolved then?
If you succeed, don’t hesitate to share if you need help.
Yes of course. Thanks @mutmut!
