In the configuration page, I don’t know if it’s possible, but it would be interesting if the menus were dynamic. For example, if I select « push button », only the options corresponding to this type of button would be proposed. And so on for the other types of buttons.
This is mainly a question of user comfort, but it could also prevent certain configuration errors likely to cause bugs.
Regarding the different buttons, I encountered several problems during my tests:
- On/Off Switch
- The colors don’t work.
- If you click too quickly several times on the button, it eventually crashes. The problem even seems to affect all other buttons.
- After a few dozen seconds, everything returns to normal, but you then no longer know the actual position of the button after its recovery.
- Tempo Button
- Same problem regarding colors: they don’t work.
- Selector
- The colors don’t work either.
- The problem of too quick clicks also occurs. The selector eventually stops responding and displays the message: « The action failed. »
That’s all for the different problems encountered during my tests.
