Docker en tag v4 ou v5?
Quick question @pierre-gilles, now that we’ve moved to v5 with the v4 tag: do we need to change the v4 tag to v5 in our docker (compose for me) and you’ll only keep v4 as v4?
or do we stay on v4 and continue with v5?
Hi @mutmut :slight_smile:
In your case, since you know what you’re doing, go ahead and switch to v5 :wink:
But in general, staying on the v4 tag isn’t a problem, as these two versions are fully backward-compatible, both tags are equivalent, and just point to the latest version of Gladys!
