I present to you DomoWallDock, a free Android app (GPL-3.0) that turns a tablet into a wall-mounted dashboard for Gladys Assistant (and Home Assistant). It’s a derivative of WallDock by psycho1807, which I adapted and reorganized for Gladys.
It is available in 4 languages (FR, EN, DE, ES).
What it brings with Gladys
The Gladys dashboard in full screen, in kiosk mode: no Android bars, screen always ready, settings protected by a code.
Ok, this has been available with Gladys for a long time.
Automatic connection with a Gladys account (I recommend a dedicated account for the tablet).
Local, external, or both access: the tablet takes the local address at home and the https address if it goes out.
The tablet becomes a device in Gladys thanks to MQTT discovery: battery, battery temperature, charging, movement, screen switch, “Reload” and “Return to Dashboard” buttons. For example, you can turn on the screen when someone rings.
Battery preserved for a tablet that is always plugged in: a “Requested Charge” sensor (30% / 80% by default) and two Gladys scenes control a connected outlet on the charger. If the tablet falls, the outlet turns back on by itself. -
Front camera: the screen turns on when someone passes and turns off when there is no one left. The images never leave the tablet. -
Gladys calendar in full screen: day, week, month, agenda.
Standby screen: clock, Immich album, tablet photos, or a Gladys page. Plus a screen turned off at night, an app dock, and alarms. -
Discreet dock allowing you to launch the apps already present on your tablet AND that you have chosen.
App in French, English, German, and Spanish, compatible with Android 7 and above (a dedicated version for Android 7).
For my part, it runs on two Amazon Fire tablets under LineageOS Android 7 from 2015 (the reason for the Android 7 version) and two Galaxy TAB A 7 10" (SM-t505 and SM-T590).
Installation
- Download the APK from the Releases.
- Follow the illustrated step-by-step tutorial and multilingual: DomoWallDock with Gladys.
Source code and Gladys / Home Assistant compatibility table: GitHub - McFlyPartages/DomoWallDock · GitHub
This is still a pre-release: your feedback is welcome, whether it’s a bug, a tablet that gets stuck, or an idea for a feature.
Domotically,
Anthony, McFly
