@prohand @David
Dite moi si avec ça vous trouvez vos sonos
https://ghcr.io/vincentbesseau/gladys-sonos:0.1.1
"manifest_version": 1,
"type": "device",
"name": "Sonos",
"description": {
"en": "Control Sonos speakers locally, including VLAN setups, and play any content URI.",
"fr": "ContrĂŽlez vos enceintes Sonos en local, y compris en VLAN, et lancez n'importe quelle URI."
"version": "0.1.1",
"docker_image": "ghcr.io/vincentbesseau/gladys-sonos:0.1.1",
"gladys_version": ">=4.86.0",
"cover_image": "https://raw.githubusercontent.com/vincentBesseau/gladys-sonos/main/cover.jpg",
"categories": [
"multimedia"
"transports": [
"local"
"network_discovery": [
"type": "ssdp",
"st": "urn:schemas-upnp-org:device:ZonePlayer:1"
"config_schema": [
"key": "intro",
"type": "section",
"label": {
"en": "Sonos, controlled locally",
"fr": "Sonos, piloté en local"
"description": {
"en": "This integration controls your Sonos speakers directly over your local network - no cloud account, no Sonos app login. It discovers them automatically (SSDP). If your Sonos speakers are on a different VLAN/subnet than Gladys, automatic discovery will not find them: fill in one known IP below instead, it is enough to recover the whole household.",
"fr": "Cette intégration pilote vos enceintes Sonos directement sur votre réseau local - aucun compte cloud, aucune connexion à l'app Sonos. Elle les découvre automatiquement (SSDP). Si vos enceintes Sonos sont sur un VLAN/sous-réseau différent de Gladys, la découverte automatique ne les trouvera pas : renseignez plutÎt une IP connue ci-dessous, cela suffit à retrouver toute l'installation."
"key": "known_ips",
"type": "string",
"label": {
"en": "Known IPs (VLAN fix)",
"fr": "IPs connues (contournement VLAN)"
"description": {
"en": "One Sonos speaker IP is enough: this integration then asks it for your whole household's layout. Separate multiple entries with a comma or a new line.",
"fr": "L'IP d'une seule enceinte Sonos suffit : l'intégration lui demande ensuite l'organisation de toute votre installation. Séparez plusieurs entrées par une virgule ou un retour à la ligne."
"placeholder": {
"en": "192.168.10.21",
"fr": "192.168.10.21"
"actions": [
"key": "scan_now",
"label": {
"en": "Scan for Sonos speakers",
"fr": "Rechercher les enceintes Sonos"
"timeout_seconds": 30
