Gladys Assistant 4.84 : Les intégrations externes sont là 🚀
Hello super nouvelle :slight_smile:
Le meilleur des deux mondes v3 v4 :star_struck:
Seul soucis :
2026-08-01T22:49:50+0200 <warn> errorMiddleware.js:71 (errorMiddleware) Error: (HTTP code 400) unexpected - NanoCPUs can not be set, as your kernel does not support CPU CFS scheduler or the cgroup is not mounted
    at /src/server/node_modules/docker-modem/lib/modem.js:336:17
    at getCause (/src/server/node_modules/docker-modem/lib/modem.js:366:7)
    at Modem.buildPayload (/src/server/node_modules/docker-modem/lib/modem.js:335:5)
    at IncomingMessage.<anonymous> (/src/server/node_modules/docker-modem/lib/modem.js:303:16)
    at IncomingMessage.emit (node:events:531:35)
    at endReadableNT (node:internal/streams/readable:1698:12)
    at processTicksAndRejections (node:internal/process/task_queues:89:21) {
  reason: undefined,
  statusCode: 400,
  json: {
    message: 'NanoCPUs can not be set, as your kernel does not support CPU CFS scheduler or the cgroup is not mounted'
Je suis sur nas synology 920+
