Hello everyone!
Itâs official: Gladys Assistant OS is available! ![]()
This is the new official way to install Gladys on a mini-PC: you write the image to a USB key, you boot the mini-PC from it, you answer a few questions, and Gladys installs itself. No more command line, no more docker run to copy-paste ![]()
Everything is explained step by step, with a screenshot of each screen, in the new documentation:
What Gladys Assistant OS does
- Under the hood, itâs a standard Ubuntu Server 26.04 LTS, prepared for Gladys
- The installer only asks for the language, the keyboard, and your account. With a single disk, thereâs not even a disk to choose
- On first boot, it installs Docker, downloads the latest version of Gladys, and launches it. You can follow the progress on the mini-PC screen or from your phone
- Gladys updates itself, and Ubuntu installs its security updates automatically
- An Internet or power outage during the first boot? It resumes where it left off
- At the end, Gladys is accessible on http://gladysassistant.local
And itâs not a black box: it remains a classic Ubuntu, accessible via SSH, with no default account or password.
What you need for this first version
- an Intel or AMD mini-PC (x86-64) that boots in UEFI, which is almost all mini-PCs
- an Ethernet cable
- a screen and a keyboard, only during installation
On Raspberry Pi, we keep the Raspberry Pi image, and the Docker installation remains for those who already have a server or a NAS. And if Gladys is already running at your place, nothing changes: no need to reinstall!
All the installation documentation revised
I took the opportunity to revise all the installation documentation (in French, English, German, and Spanish) so that Gladys Assistant OS is the first thing we see:
- Getting Started: Getting started with Gladys Assistant | Gladys Assistant
- Installing Gladys on Proxmox, rewritten around a Gladys Assistant OS VM: Install Gladys Assistant on Proxmox VE | Gladys Assistant
- The blog post: Gladys Assistant OS: install Gladys on a mini-PC from a USB drive | Gladys Assistant
A huge thank you
Gladys Assistant OS is a community project from start to finish:
- @howmationfr started the project and did most of the work
- @cicoub13 took it over, refined it, and released v0.1.0
- thanks also to everyone who tested and gave feedback in the original topic
And as always, everything is open source: GitHub - GladysAssistant/ubuntu-server-gladys: Gladys Assistant OS · GitHub
Now itâs your turn to test!
This is a first version: if you have a mini-PC on hand, install it and tell us how it went in a reply to this post! Every feedback on real hardware (Intel N100/N150, Core, AMD Ryzen, NVMe, SATAâŠ) helps to make the installer more reliable. The test checklist is here: HARDWARE-TEST-CHECKLIST.md
Donât hesitate to give your feedback on the forum ![]()
