Bonjour, j’essaie d’installer un environnement de développement pour Gladys.
Mais j’ai cette erreur lorsque j’essaie d’installer les dépendances du service USB.
Quelqu’un sait comment résoudre ce problème.
WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm ERR! code 1
npm ERR! path /home/anand/Desktop/Gladys/server/services/usb/node_modules/@serialport/bindings
npm ERR! command failed
npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! make: Entering directory '/home/anand/Desktop/Gladys/server/services/usb/node_modules/@serialport/bindings/build'
npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.o
npm ERR! make: Leaving directory '/home/anand/Desktop/Gladys/server/services/usb/node_modules/@serialport/bindings/build'
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@8.4.1
npm ERR! gyp info using node@20.9.0 | linux | x64
npm ERR! gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/home/anand/Desktop/Gladys/server/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/home/anand/Desktop/Gladys/server/services/usb/node_modules/@serialport/bindings/build/config.gypi',
npm ERR! gyp info spawn args '/home/anand/Desktop/Gladys/server/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/home/anand/.cache/node-gyp/20.9.0/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/home/anand/.cache/node-gyp/20.9.0',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/home/anand/Desktop/Gladys/server/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/home/anand/.cache/node-gyp/20.9.0/<target_arch>/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/anand/Desktop/Gladys/server/services/usb/node_modules/@serialport/bindings',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! In file included from ../../../nan/nan.h:176,
npm ERR! from ../src/./serialport.h:6,
npm ERR! from ../src/serialport.cpp:1:
npm ERR! ../../../nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’
npm ERR! 55 | typedef v8::Local<v8::AccessorSignature> Sig;
npm ERR! | ^~~~~~~~~~~~~~~~~
npm ERR! ../../../nan/nan_callbacks.h:55:40: erreur : l'argument de modèle 1 est invalide
npm ERR! | ^
npm ERR! In file included from ../src/./serialport.h:6,
npm ERR! ../../../nan/nan.h: In function ‘bool Nan::IdleNotification(int)’:
npm ERR! ../../../nan/nan.h:682:63: warning: ‘bool v8::Isolate::IdleNotificationDeadline(double)’ is deprecated: Use MemoryPressureNotification() to influence the GC schedule. [-Wdeprecated-declarations]
npm ERR! 682 | return v8::Isolate::GetCurrent()->IdleNotificationDeadline(
npm ERR! | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^
npm ERR! 683 | idle_time_in_ms * 0.001);
npm ERR! In file included from /home/anand/.cache/node-gyp/20.9.0/include/node/v8-initialization.h:13,
npm ERR! from /home/anand/.cache/node-gyp/20.9.0/include/node/v8.h:34,
npm ERR! from /home/anand/.cache/node-gyp/20.9.0/include/node/node.h:73,
npm ERR! from ../../../nan/nan.h:56,
npm ERR! /home/anand/.cache/node-gyp/20.9.0/include/node/v8-isolate.h:1293:8: note: declared here
npm ERR! 1293 | bool IdleNotificationDeadline(double deadline_in_seconds);
npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~
npm ERR! ../../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)':
npm ERR! ../../../nan/nan.h:2542:19: erreur: aucun argument correspondant à l'appel à 'v8::ObjectTemplate::SetAccessor(v8::Local<v8::String&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfov8::Value&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
