@bertrandda I found a branch with the remote control on the dashboard, it’s very old, I just updated it with the latest version of the code, but I don’t think it works as-is.
I won’t have time to get back to working on it, but if it can inspire you.
master ← remote-box
ouvert 06:40PM - 03 Jul 23 UTC
### Pull Request check-list
- [ ] If your changes affects code, did your write the tests?
- [ ] Are tests passing? (`npm test` on both front/server)
- [ ] Is the linter passing? (`npm run eslint` on both front/server)
- [ ] Did you run prettier? (`npm run prettier` on both front/server)
- [ ] If you are adding a new features/services, did you run integration comparator? (`npm run compare-translations` on front)
- [ ] Did you test this pull request in real life? With real devices? If this development is a big feature or a new service, we recommend that you provide a Docker image to [the community](https://community.gladysassistant.com/) for testing before merging.
### Description of change
Please provide a description of the change here. It's always best with screenshots, so don't hesitate to add some!
(not everything should be kept)
