External integration - Chacon DiO
cover-chacon-dio
Hi everyone!
French-style home series, episode roller shutters: the Chacon DiO modules, you can find them in the electrical section of any hardware store, and many of you have installed them behind your switches. The Wi-Fi ones, controlled by the DiO One app, are coming to Gladys.
What it does
  • Roller shutters (REV-SHUTTER): the position from 0 to 100% and the Open / Stop / Close buttons, which also show when the shutter is going up or down.
  • Light switches (REV-LIGHT) and Wi-Fi outlets: on / off.
  • DiO video doorbell: „Rings“ every time the doorbell rings.
  • Real-time: a change made from the app, the wall switch, or a remote control is immediately updated in Gladys.
  • A « Unreachable » badge when a device loses Wi-Fi or power, and the trigger that goes with it: « DiO Device Offline or Back Online ».
  • A « DiO Shutters » widget with Open All / Stop All / Close All, and a scene action « Control All DiO Shutters ».
  • In French, English, German, and Spanish.
The cool part
Sunset → all shutters closed, in one go
The freezer outlet goes offline → „Power outage in the garage? „
Someone rings → the entrance lighting turns on, and a notification on the phone
Installation
:warning: Gladys 5.1 minimum.
It will arrive in the store at the next indexer run. In the meantime: Integrations → Install from GitHub, with GitHub - guim31/gladys-chacon-dio: Chacon DiO plugs, shutters and bulbs for Gladys Assistant · GitHub
  1. Enter the email and password of your DiO One account.
  2. Discovery tab: add your devices.
Honest small reservations
  • Everything goes through Chacon’s cloud: you need Internet.
  • No bulbs, dimmers, or cameras yet: their operation is documented nowhere. The „List devices in DiO account“ button displays them with their model: if you have any, send me what it says, it will help me add them.
  • Old DiO in 433 MHz are not concerned, only the Wi-Fi models.
  • A garage door or gate connected to a shutter module is recognized (module setting in the DiO app, or a name that contains „garage“ or „gate“) and remains read-only by default: you can see if it is open, but Gladys does not open it. An option allows you to authorize it, always as a shutter and never as a switch (so not by voice), and it remains separate from the widget and „Control All Shutters“.
  • Developed without the hardware. I verified from home that the connection to the real DiO cloud goes all the way and properly rejects a fake account, but no one has used it yet with a real account: if you are equipped with DiO, your feedback interests me a lot. The real-time channel also responds well. The exact type of outlets remains to be confirmed.
Like the previous ones, developed with Claude Code. Independent project, not affiliated with Chacon.
Repository: GitHub - guim31/gladys-chacon-dio: Chacon DiO plugs, shutters and bulbs for Gladys Assistant · GitHub
The only Chacon Dio devices I have are sockets, but they are 433 MHz, not Wi-Fi. I understand that this integration doesn’t support them. But is it technically unfeasible, or could it be done as well?
433MHz is really in a league of its own… You need a gateway to bridge your device and Gladys.
I won’t go back on the name of the one supported here. I think Broadlink does that.
For 433MHz, logically it’s RFXcom, RFLink (if I’m not mistaken) or RFPlayer.
All of them are USB, so for now you have to go through a ser2net on the Gladys host (or another machine, but not the easiest).
hi so I have a visiophone (DIOVDP-IP02) and it connects via Wi-Fi in the application
but the ring in Gladys is announced at random times (not real)
with these logs [2026-10-24T21:44:55.308Z] [INFO] [chacon-dio] Starting the Chacon DiO integration…```
[2026-10-24T21:44:55.536Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-10-24T21:44:56.755Z] [INFO] [chacon-dio] Connected to the DiO cloud
[2026-10-25T15:09:44.394Z] [WARN] [gladys-sdk] connection to Gladys lost (close code 1006)
[2026-10-25T15:09:44.394Z] [WARN] [gladys-sdk] not connected to Gladys (ws://172.30.0.1:80), retrying in 1000 ms (attempt 1)
[2026-10-25T15:09:45.398Z] [ERROR] [gladys-sdk] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
[2026-10-25T15:09:45.399Z] [WARN] [gladys-sdk] not connected to Gladys (ws://172.30.0.1:80), retrying in 2000 ms (attempt 2)
[2026-10-25T15:09:47.400Z] [ERROR] [gladys-sdk] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
[2026-10-25T15:09:47.401Z] [WARN] [gladys-sdk] not connected to Gladys (ws://172.30.0.1:80), retrying in 4000 ms (attempt 3)
[2026-10-25T15:09:52.459Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-10-25T15:09:59.394Z] [INFO] [chacon-dio] Received SIGTERM → graceful shutdown
[2026-10-25T15:09:59.927Z] [INFO] [chacon-dio] Starting the Chacon DiO integration…
[2026-10-25T15:10:00.704Z] [INFO] [chacon-dio] Connected to the DiO cloud
[2026-10-26T02:00:47.703Z] [INFO] [chacon-dio] DiO device "Visiophone" is offline
[2026-10-26T02:00:51.861Z] [INFO] [chacon-dio] DiO device "Visiophone" is online
[2026-10-27T10:25:14.708Z] [INFO] [chacon-dio] Connection to the DiO cloud lost (request timed out)
[2026-10-27T10:25:14.710Z] [WARN] [chacon-dio] Reading the DiO devices failed (request timed out)
[2026-10-27T10:25:25.039Z] [INFO] [chacon-dio] Connection to the DiO cloud is back
[2026-10-27T10:25:25.220Z] [INFO] [chacon-dio] Reading the DiO devices works again
[2026-10-28T01:50:49.354Z] [INFO] [chacon-dio] Connection to the DiO cloud lost (DiO socket closed (code 1006))
[2026-10-28T01:50:59.709Z] [INFO] [chacon-dio] Connection to the DiO cloud is back
[2026-10-28T04:08:55.361Z] [INFO] [chacon-dio] DiO device "Visiophone" is offline
[2026-10-28T04:09:07.366Z] [INFO] [chacon-dio] DiO device "Visiophone" is online
[2026-10-29T01:50:28.869Z] [INFO] [chacon-dio] Connection to the DiO cloud lost (DiO socket closed (code 1006))
[2026-10-29T01:50:39.256Z] [INFO] [chacon-dio] Connection to the DiO cloud is back
[2026-10-29T01:53:44.312Z] [INFO] [chacon-dio] Connection to the DiO cloud lost (DiO socket closed (code 1006))
[2026-10-29T01:53:54.691Z] [INFO] [chacon-dio] Connection to the DiO cloud is back
[2026-10-29T17:30:15.958Z] [INFO] [chacon-dio] Connection to the DiO cloud lost (DiO socket closed (code 1006))
[2026-10-29T17:30:26.370Z] [INFO] [chacon-dio] Connection to the DiO cloud is back
[2026-10-30T03:13:12.185Z] [INFO] [chacon-dio] Connection to the DiO cloud lost (DiO socket closed (code 1006))
[2026-10-30T03:13:22.513Z] [INFO] [chacon-dio] Connection to the DiO cloud is back
[2026-11-02T21:51:06.915Z] [WARN] [gladys-sdk] connection to Gladys lost (close code 1006)
[2026-11-02T21:51:06.918Z] [WARN] [gladys-sdk] not connected to Gladys (ws://172.30.0.1:80), retrying in 1000 ms (attempt 1)
\[2026-11-02T21:51:07.996Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-02T21:51:07.998Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 2000 ms (attempt 2)
\[2026-11-02T21:51:10.002Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-02T21:51:10.002Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 4000 ms (attempt 3)
\[2026-11-02T21:51:14.004Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-02T21:51:14.004Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 8000 ms (attempt 4)
\[2026-11-02T21:51:23.438Z\] \[INFO\] \[gladys-sdk\] connected to Gladys (http://172.30.0.1:80)
\[2026-11-02T21:51:47.042Z\] \[INFO\] \[chacon-dio\] Received SIGTERM -> graceful shutdown
\[2026-11-02T21:51:47.697Z\] \[INFO\] \[chacon-dio\] Starting the Chacon DiO integration...\[2026-11-02T21:51:47.825Z\] \[INFO\] \[gladys-sdk\] connected to Gladys (http://172.30.0.1:80)
\[2026-11-02T21:51:48.373Z\] \[INFO\] \[chacon-dio\] Connected to the DiO cloud
\[2026-11-03T03:41:48.116Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-03T03:41:58.455Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-04T02:00:45.276Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is offline
\[2026-11-04T02:00:50.301Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is online
\[2026-11-04T02:53:00.109Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-04T02:53:10.456Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-04T08:12:12.242Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-04T08:12:22.615Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-05T02:33:13.598Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-05T02:33:23.932Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-06T03:05:24.216Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-06T03:05:34.592Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-07T02:00:48.192Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is offline
\[2026-11-07T02:00:52.940Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is online
\[2026-11-07T09:39:36.201Z\] \[WARN\] \[gladys-sdk\] connection to Gladys lost (close code 1006)
\[2026-11-07T09:39:36.213Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 1000 ms (attempt 1)
\[2026-11-07T09:39:37.262Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-07T09:39:37.262Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 2000 ms (attempt 2)
\[2026-11-07T09:39:39.266Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-07T09:39:39.266Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 4000 ms (attempt 3)
\[2026-11-07T09:39:43.270Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-07T09:39:43.271Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 8000 ms (attempt 4)
\[2026-11-07T09:39:53.100Z\] \[INFO\] \[gladys-sdk\] connected to Gladys (http://172.30.0.1:80)
\[2026-11-07T09:40:02.814Z\] \[INFO\] \[chacon-dio\] Received SIGTERM -> graceful shutdown
\[2026-11-07T09:40:03.444Z\] \[INFO\] \[chacon-dio\] Starting the Chacon DiO integration...\[2026-11-07T09:40:03.621Z\] \[INFO\] \[gladys-sdk\] connected to Gladys (http://172.30.0.1:80)
\[2026-11-07T09:40:04.211Z\] \[INFO\] \[chacon-dio\] Connected to the DiO cloud
\[2026-11-08T00:40:09.547Z\] \[INFO\] \[chacon-dio\] Scan requested: reading the DiO device list
\[2026-11-08T00:40:31.203Z\] \[INFO\] \[chacon-dio\] Action: list the DiO devices
\[2026-11-08T00:47:15.073Z\] \[INFO\] \[chacon-dio\] Scan requested: reading the DiO device list
\[2026-11-08T03:30:15.399Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (request timed out)
\[2026-11-08T03:30:30.432Z\] \[WARN\] \[chacon-dio\] DiO cloud unreachable (DiO socket closed (code 1006))
\[2026-11-08T03:31:00.754Z\] \[INFO\] \[chacon-dio\] DiO cloud reachable again
\[2026-11-08T03:31:00.754Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-08T13:03:02.160Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is offline
\[2026-11-09T02:00:50.669Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is online
\[2026-11-09T03:25:42.391Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-09T03:25:52.726Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-10T02:43:51.355Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-10T02:44:02.493Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-12T03:24:21.890Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (request timed out)
\[2026-11-12T03:24:21.892Z\] \[WARN\] \[chacon-dio\] Reading the DiO devices failed (request timed out)
\[2026-11-12T03:24:36.923Z\] \[WARN\] \[chacon-dio\] DiO cloud unreachable (DiO socket closed (code 1006))
\[2026-11-12T03:26:12.394Z\] \[INFO\] \[chacon-dio\] DiO cloud reachable again
\[2026-11-12T03:26:12.395Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-12T03:26:12.550Z\] \[INFO\] \[chacon-dio\] Reading the DiO devices works again
\[2026-11-13T02:34:09.211Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-13T02:34:19.548Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back\[2026-11-13T18:38:24.000Z\] \[WARN\] \[gladys-sdk\] connection to Gladys lost (close code 1006)
\[2026-11-13T18:38:24.005Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 1000 ms (attempt 1)
\[2026-11-13T18:38:25.100Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-13T18:38:25.101Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 2000 ms (attempt 2)
\[2026-11-13T18:38:27.103Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-13T18:38:27.103Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 4000 ms (attempt 3)
\[2026-11-13T18:38:31.105Z\] \[ERROR\] \[gladys-sdk\] websocket error on ws://172.30.0.1:80: connect ECONNREFUSED 172.30.0.1:80
\[2026-11-13T18:38:31.105Z\] \[WARN\] \[gladys-sdk\] not connected to Gladys (ws://172.30.0.1:80), retrying in 8000 ms (attempt 4)
\[2026-11-13T18:38:40.684Z\] \[INFO\] \[gladys-sdk\] connected to Gladys (http://172.30.0.1:80)
\[2026-11-13T18:38:50.160Z\] \[INFO\] \[chacon-dio\] Received SIGTERM -> graceful shutdown
\[2026-11-13T18:38:50.813Z\] \[INFO\] \[chacon-dio\] Starting the Chacon DiO integration...\[2026-11-13T18:38:51.000Z\] \[INFO\] \[gladys-sdk\] connected to Gladys (http://172.30.0.1:80)
\[2026-11-13T18:38:51.546Z\] \[INFO\] \[chacon-dio\] Connected to the DiO cloud
\[2026-11-14T02:00:45.632Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is offline
\[2026-11-14T02:00:50.742Z\] \[INFO\] \[chacon-dio\] DiO device "Visiophone" is online
\[2026-11-15T03:04:05.048Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (request timed out)
\[2026-11-15T03:04:05.050Z\] \[WARN\] \[chacon-dio\] Reading the DiO devices failed (request timed out)
\[2026-11-15T03:04:20.074Z\] \[WARN\] \[chacon-dio\] DiO cloud unreachable (DiO socket closed (code 1006))
\[2026-11-15T03:08:00.440Z\] \[INFO\] \[chacon-dio\] DiO cloud reachable again
\[2026-11-15T03:08:00.440Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-15T03:08:00.579Z\] \[INFO\] \[chacon-dio\] Reading the DiO devices works again
\[2026-11-15T03:21:58.459Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud lost (DiO socket closed (code 1006))
\[2026-11-15T03:22:08.813Z\] \[INFO\] \[chacon-dio\] Connection to the DiO cloud is back
\[2026-11-16T15:05:42.357Z\] \[INFO\] \[chacon-dio\] Action: list the DiO devices
\[2026-11-16T15:38:42.005Z\] \[INFO\] \[chacon-dio\] Action: list the DiO devices
What should I do?
@Philippe_B I took the liberty of editing your post to make the logs easier to read.
When you need to include them, you select all your text and you can choose the formatting with </>:
@Philippe_B thanks for the logs (and thanks @mutmut for the formatting). They show nothing abnormal: the integration does not write the rings in the logs. To find out where the problem comes from, I need to know where you see these false rings:
  • a scene that triggers (if so, what is its exact trigger: “Doorbell”, operator and value?);
  • or the dashboard card, which displays “X minutes ago”?
The integration regularly returns the “idle” (0) state of the doorbell, at most every 6 hours, so that Gladys does not think it is disconnected. A scene that triggers on any new value would then go off at these times, and not at each real ring (1).
thanks @guim31 (and thanks @mutmut for the formatting: I’ll note that)
yes, it’s the dashboard map that displays rings that don’t match reality (for example
Intercom (Ring) 3 hours ago)
and which, by the way, don’t trigger the scene I created (send me a message and turn on a light and Alexa voice message)
@Philippe_B thanks, it’s clear: the “3 hours ago” comes from the “idle” state that the integration regularly returns, it’s not a ring. The real problem is that your actual rings aren’t reaching Gladys, which is why the scene isn’t reacting. I’m preparing a version that stops these false “X hours ago” messages and adds a diagnosis of what the DiO cloud sends when you ring. I’ll let you know as soon as it’s online.
@Philippe_B the 1.1.0 version of Chacon DiO is online: the fake “Rang X hours ago” notification is fixed. For the real notification, I need to see what your videophone sends to the DiO cloud: update the integration, ring, then in the minutes that follow click on Diagnostic in the integration configuration and paste the result here. The credentials are masked :slightly_smiling_face:
Hello, here is the diagnosis after a ring
Diagnostic Chacon DiO — 2026-11-18 12:15:01 UTC
#1 Video Intercom (DIOVDP-IP02) — .wifi.doorBell.camera.videostream.
{"rt":"oic.d.videoDoorbell","href":"/v1/devices/#1","provider":"Tuya","rc":1,"t":0,"tz":"+01:00","di":"#1","n":"***","links":[{"rt":"gw.r.camera.accessoryLock","href":"accessoryLock","door":true,"gate":true},{"rt":"gw.r.upgrade","href":"upgrade","automatic":false,"modules":[{"type":"Wifi","version":"1.0.2","status":"uptodate"},{"type":"MCU","version":"1.0.0","status":"uptodate"}]},{"rt":"oic.wk.p","href":"platform","mnmn":"Tuya","mnmo":"DIOVDP-IP02"},{"rt":"gw.r.camera.streamQuality","href":"streamQuality","isHD":false},{"rt":"gw.r.lastEvent","href":"lastEvent","type":"ring","ts":"2026-11-18T11:56:25.389Z","data":{"reason":null,"image":"https://l4h-deviceevents-prod-ue5s0l.s3.eu-west-1.amazonaws.com/…"}}],"frc":true}
Messages pushed by the DiO cloud for the doorbell or not recognized (1 last) :
2026-11-18 11:56:25 {"name":"deviceState","action":"update","data":{"rt":"oic.d.videoDoorbell","href":"/v1/devices/#1","provider":"Tuya","rc":1,"t":0,"tz":"+01:00","di":"#1","n":"***","links":[{"rt":"gw.r.camera.accessoryLock","href":"accessoryLock","door":true,"gate":true},{"rt":"gw.r.upgrade","href":"upgrade","automatic":false,"modules":[{"type":"Wifi","version":"1.0.2","status":"uptodate"},{"type":"MCU","version":"1.0.0","status":"uptodate"}]},{"rt":"oic.wk.p","href":"platform","mnmn":"Tuya","mnmo":"DIOVDP-IP02"},{"rt":"gw.r.camera.streamQuality","href":"streamQuality","isHD":false},{"rt":"gw.r.lastEvent","href":"lastEvent","type":"ring","ts":"2026-11-18T11:56:25.389Z","data":{"reason":null,"image":"<226 characters>"}}],"frc":true}}
@Philippe_B thanks, that’s exactly what was needed! The DiO cloud successfully sent your 11:56 ringtone to the integration, in the format it expects. Two questions to figure out where it gets lost afterward:
  1. At 12:56 PM (Paris time), did the dashboard card display “Ringtone a few minutes ago,” and did your scene trigger?
  2. In the integration logs, is there a line around 11:56 that mentions “ring” or a ringtone? Paste the lines from that time.
I allow myself to intervene in the conversation to remind you that Chacon, like LSC and others, is Tuya rebranding.
An alternative would be to remove the device from the Chacon app and re-pair it directly via the Tuya app.
Another alternative, @guim31, would be to suggest to your Claude, if he hasn’t already, to see how Tuya manages the doorbell…
If my comment was unnecessary, please excuse me :wink:
Good luck!
Here are the logs and the dashboard map (my scene triggered and sent me a message...)
Logs
Refresh
[2026-11-17T20:30:17.000Z] [INFO] [chacon-dio] Starting the Chacon DiO integration...
[2026-11-17T20:30:17.188Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-17T20:30:17.723Z] [INFO] [chacon-dio] Connected to the DiO cloud
[2026-11-17T20:30:41.205Z] [INFO] [chacon-dio] Action: list the DiO devices
[2026-11-17T20:30:47.483Z] [INFO] [chacon-dio] Action: diagnostic
[2026-11-18T11:56:25.448Z] [INFO] [chacon-dio] Doorbell ring: "Visiophone"
[2026-11-18T12:15:01.816Z] [INFO] [chacon-dio] Action: diagnostic
[2026-11-18T12:21:53.940Z] [INFO] [chacon-dio] Doorbell ring: "Visiophone"
VIOSOPHONE
Visiophone (Doorbell)
6 hours ago
@Philippe_B great, everything is working: the two midday chimes arrived in Gladys, your scene was triggered, and the card correctly shows the last real chime (« 6 hours ago » = 12:21). It was version 1.1.0 that fixed this. Thanks for your tests :slightly_smiling_face:
@GBoulvin thanks for the Tuya lead, but no need in the end!
@guim31 thanks to you
