External integration - ista Web'conso (meters and splitters in condominiums)
[2026-11-09T14:59:01.670Z] [INFO] Starting the ista Web’conso integration...
[2026-11-09T14:59:01.922Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-09T14:59:08.160Z] [WARN] [sync] Sign-in to the ista portal failed (session_expired): the sign-in ended on the public page ista-webconso.fr/espace-client-v2/public/loginIpmp.do: no session kept
[2026-11-09T14:59:08.164Z] [INFO] [ista] Connection test: failed (status_session_not_kept)
Thanks @prohand. Same ista error page (loginIpmp.do) right after logging in: my cookie theory was therefore incorrect. To stop guessing, I need the real browser path:
  1. Log out of the ista site, open F12, Network tab, and check Preserve log.
  2. Log in with your email and password.
  3. Send me the list of lines in private message, in order, with just their name and status (200, 302…). In Firefox, the filter is called HTML, not Document.
Thanks, I just sent you a PM
Hi @guim31,
Do you need anything other than what I sent you in PM?
With version 1.1.8 I now get this message:
[2026-11-13T21:45:00.886Z] [WARN] [sync] Sign-in to the ista portal failed (session_expired): the sign-in callback answered at ista-webconso.fr/espace-client-v2/public/loginIpmp.do (HTTP 200, public page) instead of the resident's pages: no session kept; sign-in steps: GET ista-webconso.fr/espace-client-v2 302 set[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity] > GET ista-webconso.fr/espace-client-v2/ 302 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity] set[JSESSIONID] > GET ista-webconso.fr/espace-client-v2/public/home.do?dispatch 200 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,JSESSIONID] > GET ista-webconso.fr/espace-client-v2/public/home.do?dispatch 302 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,JSESSIONID] > GET login.ista.com/realms/dsp-webconso-fr/protocol/openid-connect/auth?client_id,response_type 200 set[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,route,AUTH_SESSION_ID,KC_AUTH_SESSION_HASH,KC_RESTART] > POST login.ista.com/realms/dsp-webconso-fr/login-actions/authenticate?session_code,execution,client_id,tab_id,client_data 302 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,route,AUTH_SESSION_ID,KC_AUTH_SESSION_HASH,KC_RESTART] set[KC_RESTART,KEYCLOAK_IDENTITY,KEYCLOAK_SESSION] > GET ista-webconso.fr/espace-client-v2/public/loginIpmp.do?dispatch,session_state,iss,code 200 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity] set[JSESSIONID]
[2026-11-13T21:45:00.892Z] [INFO] [ista] Connection test: failed (status_session_not_kept)
Thanks @prohand, this time the log clearly shows where it fails: when returning from the connection to loginIpmp.do, the integration does not send the session cookie JSESSIONID (it thinks it is reserved for the ista site), and the portal responds with its error page. This is the clearest lead, but I want to be sure of what your browser does before changing it.
To decide, I need two pieces of information from your browser (just the names, not the values):
  1. F12, Network tab, Preserve log, log in, click on the line loginIpmp.do, Cookies tab: the names of the cookies sent.
  2. Storage tab → Cookies → ista-webconso.fr: the SameSite column of JSESSIONID.
Here is:
Any news @guim31 ? :slight_smile:
I tried to log in with my email and password and received this message in return:
The portal accepted the login without keeping the session: report it on the forum.
@prohand yes, sorry for the wait! Your screenshot made me go back through the history: the connection still worked in 1.1.4, and it’s 1.1.5 that broke the login page’s return. I’m starting from there, a new version is coming.
@raphdoom welcome, you’ve hit this bug right on: password login is broken for everyone at the moment. I’ll let you know here as soon as the fix is live.
Hello @guim31
Thanks a lot, I’m very interested in this integration.
@prohand @Jluc I’ve gone through the entire history: the password connection never actually passed the login page return, even in 1.1.4, which just didn’t notice. The only remaining difference with your browser was how the integration is presented to the site: 1.1.9 now presents itself exactly like Firefox. Can you update and then run Test the connection and check now? If it still blocks, paste the line [WARN] [sync] for me again.
@raphdoom same for you if you can test :slightly_smiling_face:
I don’t have internet at home anymore, I should get it back tomorrow :slight_smile:
I’ll test as soon as possible :grinning_face:
I’d be happy to help, I just need to understand what needs to be done.
I assume 1.1.4 and 1.1.9 are different versions?
That’s right, you need to do “Force Update” on the Integration Supervision page.
I did update the integration to version 1.1.9 and after an attempt to run it, the same error message came back
Hi @guim31
Here are the log elements :slight_smile: 2026-11-17T16:30:09.908Z] [WARN] [sync] Sign-in to the ista portal failed (session_expired): the sign-in callback answered at Portail WEB - Erreur (HTTP 200, public page) instead of the resident’s pages: no session kept; sign-in steps: GET ista-webconso.fr/espace-client-v2 302 set[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity] > GET ista-webconso.fr/espace-client-v2/ 302 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity] set[JSESSIONID] > GET Erreur 200 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,JSESSIONID] > GET Erreur 302 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,JSESSIONID] > GET login.ista.com/realms/dsp-webconso-fr/protocol/openid-connect/auth?client_id,response_type 200 set[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,route,AUTH_SESSION_ID,KC_AUTH_SESSION_HASH,KC_RESTART] > POST login.ista.com/realms/dsp-webconso-fr/login-actions/authenticate?session_code,execution,client_id,tab_id,client_data 302 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity,route,AUTH_SESSION_ID,KC_AUTH_SESSION_HASH,KC_RESTART] set[KC_RESTART,KEYCLOAK_IDENTITY,KEYCLOAK_SESSION] > GET Portail WEB - Erreur 200 sent[ApplicationGatewayAffinityCORS,ApplicationGatewayAffinity] set[JSESSIONID]
[2026-11-17T16:30:09.918Z] [INFO] [ista] Connection test: failed (status_session_not_kept)
here is also a copy and paste of what I get in my log tab if it can help
[2026-11-17T16:49:36.173Z] [INFO] Starting the ista Web’conso integration...
[2026-11-17T16:49:36.281Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-17T16:49:42.992Z] [WARN] [gladys-sdk] connection to Gladys lost (close code 1006)
[2026-11-17T16:49:42.992Z] [WARN] [gladys-sdk] not connected to Gladys (ws://172.30.0.1:80), retrying in 1000 ms (attempt 1)
[2026-11-17T16:49:43.566Z] [INFO] Starting the ista Web’conso integration...
[2026-11-17T16:49:43.635Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
Thanks @Jluc and @raphdoom for the tests, and @mutmut for the help! Missed again: the portal still returns its error page after login. To stop searching blindly, I need to see exactly what your browser sends at this step. @Jluc, or anyone with an ista account, on a computer:
  1. Go to ista-webconso.fr while disconnected, open F12, Network tab, check Preserve log.
  3. In the list, click on the loginIpmp.do line, Headers tab, Request Headers section.
  4. Send me the list of header names in a private message, and for the Cookie line only the names of the cookies, without the values.
@raphdoom your log only shows the start: the useful line appears after clicking on Test the connection and read now. But it’s probably the same as Jluc’s, no need to repaste it :slightly_smiling_face:
I managed to do what you asked up to part 2, but from part 3 onwards, I can’t find the lines you’re asking for, and I don’t know where to look for them in all the information in the right-hand side of the browser that opened.
I’m going to work, but if you need help for tomorrow, we can do that
