Hello everyone ![]()
I present to you a new external integration for Gladys: Somfy Protect.
It connects your Somfy Protect alarm (Link, Somfy One / One+, cameras, detectors, IntelliTag, badges, smoke detectors, sirensâŠ) to Gladys.
What it does
One device per alarm (site)
- Security level modifiable from Gladys: disabled, partial, total
- « Alarm in progress » status
One device per Somfy equipment
- Motion detector: motion, battery, temperature
- IntelliTag: detection, battery
- Badge: presence (at home / absent)
- Smoke detector: smoke, battery
- Camera: live image in Gladys + switch to open/close the cover
- Lock, intercom, siren: depending on what the device reports
Real-time
- Alarms, level changes, and detections arrive in Gladys in less than a second, just like in the Somfy app.
Scenes
Triggers
- Alarm triggered (intrusion, panic, or fire), with the name of the device that detected it
- Alarm ended
- Security level changed
Actions
- Change the security level
- Stop the alarm
- Open or close a camera cover
- Take a photo with a camera (to be placed before « Send a camera image »)
Example: « When the alarm is triggered â photo from the living room camera â send on Telegram »
Another example: « When my badge leaves the house â activate the alarm »
Dashboard widget
The Somfy Protect Alarm widget displays:
- the security level and alarm status;
- unreachable devices and low batteries;
- buttons to activate the alarm.
The Disable and Stop Alarm buttons are hidden by default. You need to check « Allow disabling » in the widget. Useful if your dashboard is on a tablet in the entrance. Each button requires confirmation.
Installation
- Gladys 5.1.0 minimum
- Integrations â search for Somfy Protect â install
- Enter the email and password of your Somfy Protect account
- Click on Test the connection
- Discovery tab: create the devices
Tip: create a user dedicated to Gladys in the Somfy Protect app (Settings â Users).
Good to know
Cloud-only integration: Somfy does not offer local access. Internet is required.
The password is only sent to Somfy and is never written in the logs.
The Somfy API is not official: it can change without notice. This integration is neither made nor supported by Somfy.
Available in French, English, German, and Spanish.
Links
- Source code: GitHub - prohand/gladys-somfyprotect: Gladys external integration to connect somfy protect devices in Gladys · GitHub
- Documentation: https://github.com/prohand/gladys-somfyprotect/blob/main/docs/fr.md
This is a first version: your feedback is welcome! Tell me which devices you have and if everything is working well. For a bug, open an issue on GitHub (remember to enable « Detailed logs » and attach the logs, without your email).
Thanks! ![]()
