Logs CalDav: À quoi ça correspond?
Bonjour, bonsoir
Depuis quelques jours, j’ai ces le logs Dans Gladys
2023-03-30T14:47:01+0200 <error> calendar.syncUserCalendars.js:34 (CalDAVHandler.syncUserCalendars) Error: Bad status: 0
    at exports.XMLHttpRequest.request.onreadystatechange (/src/server/services/caldav/node_modules/dav-request/dav.js:3424:27)
    at setState (/src/server/services/caldav/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:610:14)
    at exports.XMLHttpRequest.dispatchEvent (/src/server/services/caldav/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:591:25)
    at exports.XMLHttpRequest.handleError (/src/server/services/caldav/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:532:5)
    at ClientRequest.errorHandler (/src/server/services/caldav/node_modules/xmlhttprequest/lib/XMLHttpRequest.js:459:14)
    at ClientRequest.emit (node:events:513:28)
    at TLSSocket.socketErrorListener (node:_http_client:502:9)
    at TLSSocket.emit (node:events:513:28)
    at emitErrorNT (node:internal/streams/destroy:151:8)
    at processTicksAndRejections (node:internal/process/task_queues:82:21)
    at emitErrorCloseNT (node:internal/streams/destroy:116:3)
2023-03-30T14:47:01+0200 <error> index.js:53 (Timeout.syncAllUsers [as _onTimeout]) NotFoundError: CALDAV_FAILED_REQUEST_CALENDARS
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at CalDAVHandler.syncUserCalendars (/src/server/services/caldav/lib/calendar/calendar.syncUserCalendars.js:35:11)
    at Promise.map.concurrency (/src/server/services/caldav/index.js:46:13)
2023-03-30T14:48:00+0200 <info> scene.checkCalendarTriggers.js:24 (SceneManager.checkCalendarTriggers) Checking calendar triggers at Thu, 30 Mar 2023 12:48:00 GMT
J’aurais aimé savoir à quoi ça correspond surtout que j’ai arrêté le service caldav pour tester mais celui-ci reste:
2023-03-30T15:24:00+0200 <info> scene.checkCalendarTriggers.js:24 (SceneManager.checkCalendarTriggers) Checking calendar triggers at Thu, 30 Mar 2023 13:24:00 GMT
Merci beaucoup d’avance
Salut @dahut,
Au vu de ton premier bloc de logs, j’ai l’impression que lors de la synchronisation ton service de calendrier (Google Agenda, iCloud Calendar…) n’est pas accessible. Quel service utilises tu ? Et tu synchronises ton calendrier avec un app sur ton mobile ou ton ordinateur aussi ? Si oui est ce que sur ces appareils la synchronisation fonctionne toujours ?
Cette ligne de log là est normale, c’est la vérification des évènements pour les scènes, c’est indépendant du système CalDAV.
1 « J'aime »
Salut @bertrandda
Désolé de la réponse tardive
J’utilise le service Framagenda pour mon calendrier.
Et aussi je le synchronise sur 2 ordinateurs différents via Thunderbird et ça fonctionne correctement.
Sur Gladys, ça marche 1 fois sur 2. Mais pourtant auparavant ça marche pas trop mal.
J’ai essayé de le synchroniser manuellement, de le réinitialiser etc. et ça me répond toujours synchronisation impossible et pourtant tout le calendrier Était synchronisés jusqu’il y a 15 jours.
C’est pas vraiment le problème que je m’en sers tous les jours mais j’aime bien quand tout marche correctement.
Et pour le dernier log, il vérifie toutes les minutes ?
Je vais essayer de voir si je peux reproduire avec framagenda. Pourtant je crois qu’ils ont basé leur service sur Nextcloud, et je n’ai jamais ce genres de problèmes. Tu as combien de calendriers dessus ? Ont ils quelque chose de particulier abonnements webcal, partagés avec d’autres utilisateurs framagenda…?
Oui je crois bien que c’est toutes les minutes.
J’ai 2 calendriers dessus et pas d’abonnement webcal.
J’ai activé de nouveaux le service caldav et j’ai laissé la synchronisation se faire toute seul. Celle-ci s’est effectuée correctement.
Et ce matin, j’ai eu 3 fois le même log d’erreur. Je vais voir pour l’instant si ça se produit de nouveaux.
Merci bien
