Ability to stop a camera's broadcast
I have 2 outdoor cameras and one indoor.
The idea would be to be able to stop a camera’s stream when a user is seen at home.
No need to be filmed if the user is recognized.
Hi @Tlse-vins!
Each camera has a switch to stop its stream, since Gladys 5.0. The device is not deleted.
When you disable the camera, Gladys stops the refresh, the live stream, and the images of this camera. You can reactivate it from the device page, from a widget, or with the scene action Control a device.
For your case: a scene « someone is home → disable the camera », and the reverse scene to turn it back on when leaving.
I’m moving this topic to « Delivered Requests ». If there’s still a case that doesn’t fit, open a new topic: it will be easier to follow.
