I have a solar self-consumption installation with surplus resale to EDF.
I installed a lixee box on my Linky meter to send information to Home Assistant and I’m trying to do the same in Gladys.
My lixee box sends me my consumption via the EASF01 meter and my surplus resale via the EAIT meter.
In Gladys, I can see the EASF01 meter (as well as the EASF02 and EAST meters) but I don’t see any data from the EAIT meter.
Where do you think I went wrong?
Thanks
Hello @filbou40,
Sorry for the delayed response!
You didn’t do anything wrong: Gladys can handle EAIT, it’s Zigbee2mqtt that doesn’t transmit it.
Why EAIT doesn’t appear
Zigbee2mqtt only sends the “producer” values of the ZLinky (EAIT, SINSTI, SMAXIN…) if it knows that your Linky is in producer mode. By default, it tries to guess this itself (option production set to auto), and in your case, it doesn’t seem to succeed. Therefore, Zigbee2mqtt never sends EAIT to Gladys.
The solution: force producer mode
- In Gladys, go to Integrations → Zigbee2mqtt → Devices, and click on “Open in Zigbee2mqtt” on your ZLinky.
- In Zigbee2mqtt, open the device-specific settings tab (“Settings (specific)”) and set the
production option to true. This only works in standard mode: this is your case, since you see EASF01.
- Restart Zigbee2mqtt (“Restart” button in its settings). Without this restart, Gladys does not see the new list of ZLinky values.
- In Gladys, open the “Zigbee Discovery” tab: your ZLinky displays an “Update” button. Click on it to add “Total Active Energy Injected (EAIT)”. Your other meters keep their name and history.
EAIT is recorded approximately every 10 minutes: the first value may therefore take some time to arrive.
And in energy tracking?
To be transparent: today, energy tracking calculates your consumption and its cost based on the withdrawn indexes (EAST, EASF01…). EAIT is not yet included in this calculation: you will not have the half-hourly surplus or the revenue from resale. Surplus buyback contracts are not yet managed either.
In the meantime, EAIT is recorded like any other sensor. You can display it in a “Graph” widget on your dashboard and use it in your scenes.
Small nuance: EAIT is the surplus injected into the grid, not your solar production. What you self-consume never goes through the Linky. For total production, you need a measurement on the inverter side. On the other hand, for your second installation in full resale, a second ZLinky set up the same way would directly give you its production: on this Linky, EAIT corresponds to everything that is produced.
If you want to see the surplus and resale in energy tracking, don’t hesitate to create a feature request: other users in self-consumption will be able to vote for it.
Hi @pierre-gilles,
Thanks for your detailed reply and no worries about the response time, I can imagine you have other things to do
I’ve done all the steps you indicated. Everything is OK. Thanks again.
For the energy follow-up, I’ll make a request on the forum.
Note that I have an EAST meter but I don’t understand the number as it is equal to my EASF01 meter (consumption) + EASF02 (which is mentioned as inactive index 2 on my Linky meter). Or maybe it’s old meters from when I was on HP/HC (I’m on base now).
Thanks again
