Pronote integration
The widget with a daily display is a bit of a hassle to configure, but it remains more versatile. And normally, you only do this configuration once. So, for me, it seems like a good solution.
Thanks for your feedback @Prof_Techno!
A Gladys widget can’t display columns: it only shows a single list. So I did it differently, in version 0.0.10, available now.
« PRONOTE Schedule » Widget
  • New Offset setting, from 0 to 7 (0 by default, as before).
  • It advances the displayed day by 1 to 7 school days. Weekends and holidays are skipped.
To Have a Column per Day
  1. Add the widget 5 times, side by side on the dashboard.
  2. Set Day to « Next School Day » in all 5 widgets.
  3. Set an Offset of 0, 1, 2, 3, and 4.
You then have the next 5 school days, one per column, with the same layout as for a single day.
To take advantage of this, update the integration, then open the widget settings on the dashboard.
Let me know if this matches what you had in mind! :slightly_smiling_face:
Honestly, it seems great to me! The 5 columns took me barely a minute to set up, so nothing complicated. And on the PC screen, the display looks great!
Personally, I think the Pronote integration can go to version 1.0. For me, it’s already well developed and everything I’ve tested works well!
Thanks for the feedback :wink:
I’ll include it in version 1 when I update the dependencies
