Here is the JSON. Thanks in advance.
"id": 2,
"name": "Radiator",
"loc": "Living Room",
"values": [
"id": "2-37-0-currentValue",
"nodeId": 2,
"toUpdate": false,
"commandClass": 37,
"commandClassName": "Binary Switch",
"endpoint": 0,
"property": "currentValue",
"propertyName": "currentValue",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Current value",
"stateless": false,
"commandClassVersion": 1,
"list": false,
"isCurrentValue": true,
"targetValue": "37-0-targetValue",
"lastUpdate": 1782583821928
"id": "2-37-0-targetValue",
"nodeId": 2,
"toUpdate": false,
"commandClass": 37,
"endpoint": 0,
"property": "targetValue",
"propertyName": "targetValue",
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Target value",
"stateless": false,
"list": false,
"lastUpdate": 1782583821929
"id": "2-38-0-targetValue",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"commandClassName": "Multilevel Switch",
"endpoint": 0,
"type": "number",
"readable": true,
"writeable": true,
"stateless": false,
"commandClassVersion": 3,
"min": 0,
"max": 99,
"list": false,
"value": 30,
"lastUpdate": 1792345354673,
"newValue": 30
"id": "2-38-0-currentValue",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"endpoint": 0,
"type": "number",
"readable": true,
"writeable": false,
"stateless": false,
"min": 0,
"max": 99,
"list": false,
"value": 30,
"targetValue": "38-0-targetValue",
"lastUpdate": 1792345359764,
"newValue": 30
"id": "2-38-0-Up",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"endpoint": 0,
"property": "Up",
"propertyName": "Up",
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Perform a level change (Up)",
"ccSpecific": {
"switchType": 2
"stateless": false,
"list": true,
"states": [
"text": "Start",
"value": true
"text": "Stop",
"value": false
"id": "2-38-0-Down",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"endpoint": 0,
"property": "Down",
"propertyName": "Down",
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Perform a level change (Down)",
"ccSpecific": {
"switchType": 2
"stateless": false,
"list": true,
"states": [
"text": "Start",
"value": true
"text": "Stop",
"value": false
"id": "2-38-0-duration",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"endpoint": 0,
"property": "duration",
"propertyName": "duration",
"type": "duration",
"readable": true,
"writeable": false,
"label": "Remaining duration",
"stateless": false,
"list": false,
"value": {
"unit": "seconds"
"lastUpdate": 1782583821930,
"newValue": {
"unit": "seconds"
"id": "2-38-0-restorePrevious",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"endpoint": 0,
"property": "restorePrevious",
"propertyName": "restorePrevious",
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Restore previous value",
"stateless": false,
"list": true,
"states": [
"text": "Restore",
"value": true
"lastUpdate": 1782583821931
"id": "2-49-0-Air temperature",
"nodeId": 2,
"toUpdate": false,
"commandClass": 49,
"commandClassName": "Multilevel Sensor",
"endpoint": 0,
"property": "Air temperature",
"propertyName": "Air temperature",
"type": "number",
"readable": true,
"writeable": false,
"label": "Air temperature",
"ccSpecific": {
"sensorType": 1,
"scale": 0
"stateless": false,
"unit": "°C",
"list": false,
"value": -999.9,
"lastUpdate": 1792332365277,
"newValue": -999.9
"id": "2-112-0-1",
"nodeId": 2,
"toUpdate": false,
"commandClass": 112,
"commandClassName": "Configuration",
"endpoint": 0,
"property": 1,
"propertyName": "Input 1 Switch Type",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 1 Switch Type",
"default": 1,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"allowManualEntry": false,
"states": [
"text": "Mono-Stable switch type (Push button)",
"value": 0
"text": "Bi-Stable switch type",
"value": 1
"value": 1,
"lastUpdate": 1766750024255,
"newValue": 1
"id": "2-112-0-2",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 2,
"propertyName": "Input 2 Switch Type",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 2 Switch Type",
"default": 1,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"value": 0
"value": 1
"value": 1,
"lastUpdate": 1766750029084,
"newValue": 1
"id": "2-112-0-3",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 3,
"propertyName": "Input 3 Switch Type",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 3 Switch Type",
"default": 1,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"value": 0
"value": 1
"value": 1,
"lastUpdate": 1766750033900,
"newValue": 1
"id": "2-112-0-4",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 4,
"propertyName": "Input 1 Contact Type",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 1 Contact Type",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"text": "NO (Normally open) input type",
"value": 0
"text": "NC (Normally close) input type",
"value": 1
"value": 0,
"lastUpdate": 1766750038720,
"newValue": 0
"id": "2-112-0-5",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 5,
"propertyName": "Input 2 Contact Type",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 2 Contact Type",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"value": 0
"value": 1
"value": 0,
"lastUpdate": 1766750045384,
"newValue": 0
"id": "2-112-0-6",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 6,
"propertyName": "Input 3 Contact Type",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 3 Contact Type",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"value": 0
"value": 1
"value": 0,
"lastUpdate": 1766750051164,
"newValue": 0
"id": "2-112-0-11",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 11,
"propertyName": "Input 1 Operation Mode Selection",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 1 Operation Mode Selection",
"default": 1,
"stateless": false,
"min": 0,
"max": 6,
"list": true,
"states": [
"text": "Button does not influence on selected mode",
"value": 0
"text": "Comfort",
"value": 1
"text": "Comfort -1 °C",
"value": 2
"text": "Comfort -2 °C",
"value": 3
"text": "Eco mode",
"value": 4
"text": "Frost protection",
"value": 5
"text": "Stop",
"value": 6
"lastUpdate": 1782583821937
"id": "2-112-0-12",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 12,
"propertyName": "Input 2 Operation Mode Selection",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 2 Operation Mode Selection",
"default": 4,
"stateless": false,
"min": 0,
"max": 6,
"list": true,
"states": [
"value": 0
"text": "Comfort",
"value": 1
"value": 2
"value": 3
"text": "Eco mode",
"value": 4
"value": 5
"text": "Stop",
"value": 6
"id": "2-112-0-13",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 13,
"propertyName": "Input 3 Operation Mode Selection",
"type": "number",
"readable": true,
"writeable": true,
"label": "Input 3 Operation Mode Selection",
"default": 5,
"stateless": false,
"min": 0,
"max": 6,
"list": true,
"states": [
"value": 0
"text": "Comfort",
"value": 1
"value": 2
"value": 3
"text": "Eco mode",
"value": 4
"value": 5
"text": "Stop",
"value": 6
"id": "2-112-0-30",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": 30,
"propertyName": "State After Power Failure",
"type": "number",
"readable": true,
"writeable": true,
"label": "State After Power Failure",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"text": "Previous state",
"value": 0
"text": "Always off",
"value": 1
"id": "2-114-0-productId",
"nodeId": 2,
"toUpdate": false,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"stateless": false,
"commandClassVersion": 2,
"min": 0,
"max": 65535,
"list": false,
"value": 81,
"lastUpdate": 1766749872089,
"newValue": 81
"id": "2-114-0-productType",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 4,
"lastUpdate": 1766749872092,
"newValue": 4
"id": "2-114-0-manufacturerId",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": "manufacturerId",
"propertyName": "manufacturerId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 345,
"lastUpdate": 1766749872098,
"newValue": 345
"id": "2-134-0-hardwareVersion",
"nodeId": 2,
"toUpdate": false,
"commandClass": 134,
"commandClassName": "Version",
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version",
"stateless": false,
"list": false,
"value": 1,
"lastUpdate": 1766749875042,
"newValue": 1
"id": "2-134-0-firmwareVersions",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateless": false,
"list": false,
"value": [
"2.0",
"1.0"
"lastUpdate": 1766749875044,
"newValue": [
"2.0",
"1.0"
"id": "2-134-0-protocolVersion",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateless": false,
"list": false,
"value": "5.3",
"lastUpdate": 1766749875047,
"newValue": "5.3"
"id": "2-134-0-libraryType",
"nodeId": 2,
"toUpdate": false,
"endpoint": 0,
"property": "libraryType",
"propertyName": "libraryType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"stateless": false,
"list": true,
"states": [
"text": "Unknown",
"value": 0
"text": "Static Controller",
"value": 1
"text": "Controller",
"value": 2
"text": "Enhanced Slave",
"value": 3
"text": "Slave",
"value": 4
"text": "Installer",
"value": 5
"text": "Routing Slave",
"value": 6
"text": "Bridge Controller",
"value": 7
"text": "Device under Test",
"value": 8
"text": "N/A",
"value": 9
"text": "AV Remote",
"value": 10
"text": "AV Device",
"value": 11
"value": 3,
"lastUpdate": 1766749875051,
"newValue": 3
"id": "2-38-0-event",
"nodeId": 2,
"toUpdate": false,
"commandClass": 38,
"endpoint": 0,
"property": "event",
"propertyName": "event",
"type": "number",
"readable": true,
"writeable": false,
"label": "Event value",
"stateless": true,
"min": 0,
"max": 255,
"list": false,
"lastUpdate": 1782605342774
"id": "2-48-0-Any",
"nodeId": 2,
"toUpdate": false,
"commandClass": 48,
"commandClassName": "Binary Sensor",
"endpoint": 0,
"property": "Any",
"propertyName": "Any",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Sensor state (Any)",
"ccSpecific": {
"sensorType": 255
"stateless": false,
"commandClassVersion": 0,
"list": false,
"value": false,
"lastUpdate": 1792042522819,
"newValue": false
"groups": [
"title": "Lifeline",
"endpoint": 0,
"value": 1,
"maxNodes": 1,
"isLifeline": true,
"multiChannel": true
"title": "Multilevel",
"endpoint": 0,
"value": 2,
"maxNodes": 16,
"isLifeline": false,
"title": "Basic on/off",
"endpoint": 0,
"value": 3,
"maxNodes": 16,
"title": "Basic on/off - input I2",
"endpoint": 0,
"value": 4,
"maxNodes": 16,
"title": "Basic on/off - input I3",
"endpoint": 0,
"value": 5,
"maxNodes": 16,
"title": "Unnamed group 6",
"endpoint": 0,
"value": 6,
"maxNodes": 16,
"neighbors": [],
"ready": true,
"available": true,
"hassDevices": {},
"failed": false,
"inited": true,
"eventsQueue": [
"time": "2026-10-18T17:11:31.778Z",
"event": "value updated",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:11:31.921Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:12:31.630Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:12:31.960Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:12:31.985Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:13:31.878Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:13:31.993Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:14:32.110Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:14:33.023Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:15:32.699Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:15:39.537Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:16:32.170Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:16:32.171Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:16:33.090Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:17:33.472Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:17:33.473Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:17:34.121Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:18:38.029Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:18:38.244Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:19:32.611Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:19:32.612Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:19:33.190Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:20:32.451Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:20:32.452Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:20:37.557Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:21:32.448Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:21:37.517Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:22:32.515Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:22:32.516Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:22:33.281Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:23:33.270Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:23:35.314Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:24:33.715Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:24:33.716Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:24:35.343Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:25:33.687Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:25:33.688Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:25:34.371Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:26:33.819Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:26:34.399Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:27:33.607Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:27:33.608Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:27:35.437Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:28:33.309Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:28:38.379Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:29:33.370Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:29:33.371Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:29:33.493Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:29:33.515Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:30:32.743Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:30:32.744Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:30:37.811Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:31:34.344Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:31:35.551Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:32:34.440Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:32:35.594Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:33:33.898Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:33:33.900Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:33:34.616Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:34:33.736Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:34:34.648Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:35:33.304Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:35:33.305Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:35:33.675Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:36:33.328Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:36:33.329Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:36:33.710Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:37:34.794Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:37:35.736Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:38:34.923Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:38:34.924Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:38:36.778Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:39:34.395Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:39:34.802Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:40:34.747Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:40:34.748Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:40:35.832Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:41:34.962Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:41:35.864Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:42:34.673Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:42:34.674Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:42:39.742Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:42:39.764Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:43:34.335Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"time": "2026-10-18T17:43:34.336Z",
"args": [
"commandClass": 38,
"endpoint": 0,
"newValue": 30,
"prevValue": 30,
"status": "Alive",
"interviewStage": "Complete",
"priorityReturnRoute": {},
"customReturnRoute": {},
"prioritySUCReturnRoute": false,
"customSUCReturnRoutes": [],
"availableFirmwareUpdates": [],
"firmwareUpdatesDismissed": {},
"lastFirmwareUpdateCheck": 0,
"hexId": "0x0159 0x0004-0x0051",
"dbLink": "https://devices.zwave-js.io/?jumpTo=0x0159:0x0004:0x0051:2.0",
"manufacturerId": 345,
"productId": 81,
"productType": 4,
"deviceConfig": {
"filename": "/usr/src/app/store/.config-db/devices/0x0159/zmnhjd.json",
"isEmbedded": true,
"manufacturer": "Qubino",
"label": "ZMNHJD",
"description": "Flush Pilot",
"devices": [
"productType": 4,
"productId": 81
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"preferred": false,
"associations": {},
"paramInformation": {
"_map": {}
"productLabel": "ZMNHJD",
"productDescription": "Flush Pilot",
"firmwareVersion": "2.0",
"protocolVersion": 3,
"zwavePlusVersion": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 5,
"nodeType": 1,
"endpointsCount": 3,
"endpoints": [
"index": 0,
"label": "Root Endpoint",
"deviceClass": {
"basic": 4,
"generic": 17,
"specific": 1
"isSecure": false,
"security": "None",
"supportsSecurity": false,
"supportsBeaming": true,
"isControllerNode": false,
"isListening": true,
"isFrequentListening": false,
"isRouting": true,
"keepAwake": false,
"maxDataRate": 100000,
"deviceClass": {
"basic": 4,
"generic": 17,
"specific": 1
"lastActive": 1792345414335,
"firmwareCapabilities": {
"firmwareUpgradable": false
"protocol": 0,
"deviceId": "345-81-4",
"hasDeviceConfigChanged": false,
"statistics": {
"commandsTX": 177339,
"commandsRX": 178549,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 441,
"lastSeen": "2026-10-18T17:43:34.335Z",
"rtt": 70.5,
"rssi": -72,
"lwr": {
"protocolDataRate": 3,
"repeaters": [],
"rssi": -72,
"repeaterRSSI": []
"nlwr": {
"protocolDataRate": 2,
"repeaters": [
8,
17
"rssi": -71,
"repeaterRSSI": [
-57,
127
"supportsTime": false,
"_name": "Radiateur (Salon)",
"applicationRoute": false,
"lastTransmit": 1792345359764,
"errorReceive": false,
"errorTransmit": false
