RSTP Camera: "send by message" bug
After some research, I confirm two things :
  1. It’s probably a bug
  2. There’s an error with ffmpeg
Update every 2 seconds, after a few minutes:
Same, one minute later:
Same one minute later:
You can see a lot of new ffmpeg threads, never closed (should there be a 2-second timeout otherwise?).
Finally, I changed the port used for RTSP on my camera (#DIY) and I still see threads using the old port. Proof they were not stopped in time.
Note: I use the camera on only one dashboard, which wasn’t even open at the time of the tests and screenshots.
So it’s 100% related to this thread: Gladys utilisation de la ram
