Tp-link KASA integration supported devices Note on using EP10P4 WiFi plug mini
@cicoub13
Please add an additional note to your excellent Integration explanation:
Do not perform a firmware upgrade to the tp-link KASA EP10P4 if you plan to use it with Gladys Assistant. The firmware upgrade from 1.0.5 to 1.1.1 causes the EP10P4 to use the newer KLAP protocol, which causes the EP10P4 to not be discovered in a devices scan. Without the firmware upgrade, the device is usable with Gladys.
Regarding your many contributions to Gladys, thank you!
Hello
Thanks for the feedback, it’s done and available in the docs of the latest version.
A device disappeared from the scan after a firmware update. Some Kasa models switch to the KLAP protocol when their firmware is updated. This is particularly the case for the EP10P4 plug: firmware 1.1.1 (installed since version 1.0.5) switches it to KLAP, and it is then no longer detectable. Do not update this firmware if you plan to use the device with Gladys; with firmware 1.0.5, everything works.
Thanks for the compliments.
