[Tutorial] Integrate an LSC camera into Gladys via RTSP
Thanks! I just tried it and it works! However, the blue LED stays on all the time. But I was able to cut the camera’s internet connection and keep it running locally! Great! It’s an LSC Smart dual‑band camera, version V3.2863.105, in case that helps. A small detail: I first tried with a 128GB SD card and it didn’t work. Then I did the same thing with an 8GB card (following ChatGPT’s advice :slight_smile: ) and it worked! For your information, I had this text translated, so sorry if there are any mistakes :slight_smile:
