Non-numeric value in a condition
Thanks for the details :slight_smile:
Do you have a way to modify this custom API?
This custom API could return an integer instead of a string, which would also match the native music features we currently have in Gladys:
Using these native features would also let you use the player on the dashboard with your MPD server:
Ideally, if you can modify the custom API to send state changes via MQTT to Gladys, that would allow you to have the music widget always up to date on your dashboard :slight_smile:
If this is something that works for you, I can walk you through the entire procedure! And honestly, I think it’s a better solution than using a string that doesn’t correspond to anything in Gladys :slight_smile:
