Sonoff TRVZB thermostatic valve
I installed a new SonoFF TRVZB thermostatic valve on the kitchen radiator, but in the configuration sheet, the valve switch does not appear; therefore, it is not possible to use the thermostat function.
Hi @Jluc, I took the liberty of moving your message to a new topic dedicated to your thermostatic valve.
Then I’m not sure if the valve is fully supported in Gladys. If the valve really exposed a switch, you would find it in the list.
If we look at the zigbee2mqtt website, here is the list of what is exposed:
Could you provide us with a screenshot of the zigbee2mqtt integration page in Gladys to see what is actually recognized?
Thanks in advance.
