Hello, I’m looking to buy an irrigation valve compatible with Gladys. Do you have a model to recommend?
At my place, I installed a Sonoff valve that works well for the switch part.
However, for the flow rate (ok in z2m), it is not yet integrated into Gladys, so it is not directly visible.
You would need to go through a virtual MQTT device and subscribe to the flow rate topic.
In general, if it is supported by zigbee2mqtt, it is supported by Gladys (with a few exceptions of « uncommon » features and therefore not yet implemented).
Okay, great then, the speed isn’t important to me, thanks for the reply, I’ll place my order.
I use this one:
If you haven’t ordered yet, I have this one on my side (on AliExpress):
