The external integration gladys-teltonika by @LM1LC3N7 allows you to retrieve information from Teltonika 4G/5G routers (RutOS 7+) in Gladys, via the router’s local HTTP API.
What is retrieved today:
Whether mobile data is connected or not
Signal: bars, RSSI, RSRP, RSRQ, SINR
Operator, network type, band, SIM card
Modem temperature
Upload/download speeds, received/sent volume
Router firmware + restart button (disabled by default)
The need:
Display this information neatly on the dashboard. With the current widgets, it’s just a simple list of values, which is not very readable.
What I propose: a “Mobile Router” widget with:
A signal icon in bars (like on a phone)
The operator and network type (4G / 5G) clearly visible
A green/red indicator for the connection status
Real-time speeds
Optional: the restart button
Why this is useful:
Many users have a 4G/5G box as a backup or in a secondary residence
See at a glance if the connection is good, without opening the router interface
Would others be interested?
@lmilcent, would this be possible on the integration side? And on the Gladys team side, is this feasible, or should we rather go through a generic “signal quality” widget that can be reused by other integrations?
Great idea @prohand! Yes, it’s possible on the integration side, without waiting for the Gladys team: an external integration can now declare its own widgets. I’m on it: a “Mobile Router” widget with signal bars, the operator and network type, the connection indicator, and the data rates. The restart button will only be there if you’ve enabled it in the configuration. I’ll let you know here as soon as it’s published.
What it displays, for a modem of your router (chosen in the widget settings):
the operator name;
the signal in bars, like on a phone (red, orange or green);
the network type (4G, 5G NSA…);
the download and upload speeds;
two indicators: mobile data connected or not, router responding or not.
An unknown value is displayed as « unknown », never guessed. The « Restart » button only appears if you have authorized the restart in the configuration, and Gladys asks for confirmation. Warning: any user who sees the widget can then use it. Right after, the widget displays « Restart sent » and waits for the next reading.
I don’t have a Teltonika router: everything was tested on a fake router and in a test Gladys. Let me know what it looks like on your dashboard!
