Me permito intervenir aquí porque mi problema está relacionado. Si es necesario, puedo crear un tema separado.
Al intentar modificar una de mis tomas, me encuentro con esta pantalla:
He movido el tema a un nuevo tema.
Efectivamente, hay un error al iniciar Gladys
2024-01-04T11:31:10+0100 <error> index.js:16 (process.<anonymous>) TypeError: No se puede desestructurar la propiedad 'model' de 'definition' ya que es nula.
at convertDevice (/src/server/services/zigbee2mqtt/utils/convertDevice.js:13:11)
at /src/server/services/zigbee2mqtt/lib/getDiscoveredDevices.js:14:17
at Array.map (<anonymous>)
at Zigbee2mqttManager.getDiscoveredDevices (/src/server/services/zigbee2mqtt/lib/getDiscoveredDevices.js:14:6)
at Zigbee2mqttManager.handleMqttMessage (/src/server/services/zigbee2mqtt/lib/handleMqttMessage.js:36:23)
at MqttClient.<anonymous> (/src/server/services/zigbee2mqtt/lib/connect.js:64:12)
at MqttClient.emit (node:events:517:28)
at MqttClient._handlePublish (/src/server/services/zigbee2mqtt/node_modules/mqtt/lib/client.js:1277:12)
at MqttClient._handlePacket (/src/server/services/zigbee2mqtt/node_modules/mqtt/lib/client.js:410:12)
at work (/src/server/services/zigbee2mqtt/node_modules/mqtt/lib/client.js:321:12)
at Writable.writable._write (/src/server/services/zigbee2mqtt/node_modules/mqtt/lib/client.js:335:5)
at doWrite (/src/server/services/zigbee2mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139)
at writeOrBuffer (/src/server/services/zigbee2mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5)
at Writable.write (/src/server/services/zigbee2mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
at Socket.ondata (node:internal/streams/readable:809:22)
at Socket.emit (node:events:517:28)
at addChunk (node:internal/streams/readable:368:12)
at readableAddChunk (node:internal/streams/readable:341:9)
at Socket.Readable.push (node:internal/streams/readable:278:10)
at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
De hecho, la versión 1.35 detecta los dispositivos desconocidos y, por lo tanto, el Coordinator (el dongle Zigbee).
Lo que hizo @AlexTrovato permitía mapear automáticamente los dispositivos desde su modelo. Pero algunos dispositivos detectados no tienen modelo actualmente.
Voy a proponer una imagen para probar el parche.
Lo corrijo, el modelo es un simple atributo/parámetro del dispositivo, no sirve para mapear los dispositivos ni sus características.
Son las « exposes » las que permiten construir los dispositivos con sus características.
En cambio, si el modelo no se proporciona, no debería haber problema… por lo tanto, es un error en efecto…
Edito: Al releerlo, me doy cuenta de que la frase anterior, sin la entonación, puede prestarse a confusión… De verdad les digo ‹ gracias ›
Y no es una orden.
Creo que hubo un malentendido con tu mensaje anterior @AlexTrovato ^^
Debió inducir a error, en la primera lectura también creí que estabas haciendo la corrección, pero al final no creo que sea así. ^^
@cicoub13, ¿ya tienes algo funcional? ¿Tienes tiempo?
Si no, puedo echar un vistazo mañana, puse en marcha mi zigbee el lunes y, efectivamente, después de depurar, creí ver que el error venía del coordinador que no exponía toda la información.
Tengo algo funcional aquí (también disponible con la imagen cicoub13/gladys:fix-zigbee-discovery).
Si @AlexTrovato no puede proponer nada para el lunes, esto puede corregir el problema.
Pero sería más interesante aprovechar la nueva versión de zigbee que permite controlar dispositivos desconocidos (si podemos hacer el mapeo de las características en Gladys).
