Access Gladys on Android smartphone
Before version 5.3
I couldn’t open a User account for my daughter, email: xxxxxxx@gmail.com…
It doesn’t seem to recognize the email address, yet it exists…
Reason: Incorrect email/password.
Same for my wife: yyyyyyy@orange.fr
Whether I make them admin or user…
However, mine works fine: jpjpjpj@orange.fr.
Particularity: all three from Android smartphones.
When I run it on a Windows PC, no issues.
Pierre-Gilles’ response:
Thanks for your feedback, and well spotted for the phone/PC difference: that’s exactly it. On Android, the keyboard automatically capitalizes the first letter of the email address, and Gladys didn’t recognize the address in this case.
Until the next update, you can log in from your phone by checking that the address is typed all in lowercase (no space at the end).
The fix is done and will arrive in the next version of Gladys.
Version 5.3 is in place without the corrective effect and now on PC, only my admin user can access it, whereas before the other two worked on PC.
Thank you for the feedback. The fix (capitalization and trailing space) is indeed part of version 5.3: the entered address is now converted to lowercase and stripped of spaces before being compared to the stored one.
The fact that it no longer works on PC for your daughter and wife makes me think that their address was registered with a trailing space when the account was created. Before, it worked on PC because the input matched exactly. Now, Gladys removes the space on login, so the address no longer matches.
You can try this from your admin account:
  1. Go to Settings > Users and edit each affected account.
  2. Re-enter the email address properly (without spaces) and reset the password.
  3. Save, then try logging in with these accounts, first on PC and then on Android.
If it still doesn’t work, let us know:
  • the exact error message;
  • whether you are logging in locally (box IP) or via Gladys Plus;
  • the container logs at the time of the attempt (Settings → System → Download logs).
Tests after response of 26/10
2. Re-enter the email address properly (no spaces) and reset the password.
3. Save, then try logging in with these accounts, first on PC then on Android.
Preliminary operation completed.
Connection to Gladys
Test on PC Windows simulated locally by OPEN VPN as I am traveling …:
For my wife: OK
For my daughter: OK
==== By the way I tested the forgotten password: SMTP message received but no link ….
However, I did receive the log:
2026-10-27T21:11:31.220047250Z 2026-10-27T22:11:31+0100 user.controller.js:208 (forgotPassword) Forgot password initiated for user yyyyyyy@orange.fr, link = http://192.168.1.23/reset-password?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1c2VyX2lkIjoiOWNlZmQzYTEtYjQzOC00NWI2LWEzNjgtMGY3NDU1MWEy
Test simulated locally on Android:
For my wife: OK
For my daughter: OK
Connection to Gladys +
Test on PC Windows
For me: 2FA requested
Both my wife and my daughter: negative.
Message: Email / password incorrect
Tests on Android :
No 2FA request
Same:
I retested twice but couldn’t get the message on Android:
Message: Invalid email address or password
Question: no error code … which keyword to search for in the log file that I have kept anyway?
Hi everyone!
This topic is now in development.
A PR has been opened to standardize already registered emails (spaces/case) so that affected accounts can log in again:
Feel free to follow the PR, test (optional, especially for small requests) and provide your feedback here if needed.
Hi everyone!
A PR has been opened to send the text and the password reset link in a single message:
Feel free to follow the PR, test (optional, especially for small requests) and give your feedback here if needed.
Thanks for these detailed tests, they helped me find the cause of each issue :+1:
1. Connection of your wife and daughter
The fact that it works again after re-registering the addresses confirms the explanation: they had been registered with a space at the end (the phone keyboard often adds one after a suggestion). Since version 5.3, Gladys cleans the address you type, but not those already registered. So they no longer matched, even on PC.
In the next version, Gladys will automatically clean existing addresses at startup, so no one else will have to do this manipulation again.
2. Forgotten password: email received without link
Well spotted, it’s a real bug. Gladys was sending two separate messages: first the text « Here is the link: », then the link alone. By email, this gives two emails, and the second, which only contains a link to a local IP address, is often classified as spam. Check your wife’s spam folder, it’s probably there.
In the next version, the text and the link will be sent in a single message.
A small tip by the way: avoid pasting these links in full on the forum, they allow changing the account password. The one in your message was cut off, so no risk here.
3. Gladys Plus: your wife ends up on your account
This has nothing to do with the fact that you are the only administrator: it’s normal, other accounts don’t need to be.
Gladys Plus accounts and Gladys users are separate. At the first connection of a Gladys Plus account, Gladys asks which user to link it to, then remembers this choice. I think your first name was chosen at that time for your wife’s account. She therefore uses Gladys under your name, with your administrator rights.
Do you remember this « Link to a Gladys user » screen, and the name chosen?
In the meantime, I can reset this link on my side: send me a private message with the email address of your wife’s Gladys Plus account. At her next connection, Gladys will ask her again which user to link to, and she will be able to choose hers.
Today, there is no way to change this link afterwards, and it’s a lack. I’m looking into allowing it to be modified, and to display in Settings > Gladys Plus which user each account is linked to.
Actually, I modified it for both of them. So others can benefit from this correction, and that’s great.
  1. Forgotten password: email received without link
The message with the link was indeed in the SPAM, didn’t think of that…
3. Gladys Plus: your wife appears on your account
Sorry, I unfortunately don’t remember this message.
I will send my wife’s address via private email.
Simple question: What does a revocation correspond to? Is it irreversible or can it be recreated? A mistake is still possible …
.JP
Thanks for the address, it’s done: I’ve removed the link between your wife’s Gladys Plus account and your local user.
She must log out of Gladys Plus and then log back in. Upon logging in, the « Configure Gladys Plus » screen will ask her to select her Gladys user: she must choose hers this time :slightly_smiling_face: After that, she will use Gladys under her name, with her own rights, and no longer yours.
Great for the email in the spam, it confirms the diagnosis. In the next version, the text and link will be sent in a single message.
On revocation, there are two different things:
  1. « Revoke » in Plus Users (the trash can next to a user): this deletes their Gladys Plus account and immediately logs them out of all their devices. It’s not final: you can re-invite them with the same address. But it will be a new account, like a first registration. Therefore, you will need to:
    • have her choose a password and reconfigure her 2FA;
    • authorize her again from Gladys locally, in Settings > Gladys Plus > Remote Users;
    • have her choose her Gladys user again upon first login.
    If the invitation has not yet been accepted (status « pending »), revoking it simply cancels the invitation, and you can send another one.
  2. Cut access without deleting anything: from Gladys locally, in Settings > Gladys Plus, section « Remote Users », the switch next to each user allows or blocks their access to your instance. You reactivate it and access is restored, without having to do anything else.
So to temporarily block someone, or if you have doubts, use the switch. Keep the trash can to really remove someone from your Gladys Plus subscription. Even in case of error, it can be fixed with a new invitation.
It’s all good… thanks.
