It would be convenient to have a button directly accessible in the list of updates rather than having to open each module, go to the monitoring tab to finally access the update.
A global update button would indeed be very welcome, I just did 14 of them, it takes a bit of time ![]()
Either a global button, or a button visible on the card of the concerned integration, that directly launches the update, at least we wouldnât need to go back and forth anymore.
Especially since now, people will have 20 integrations installed each ![]()
I agree, because itâs long when you have to update everything and this quite frequently.
I did indeed propose this a few days ago, but I think it wasnât followed up⊠In any case, Iâm for it!
Thanks,
Have a nice day,
Jean
I think both proposals really make sense, well done!!
I like this one and I would say that if we have an update with the black Update button, then we no longer need the small blue badge that says there is an update (and which I didnât find very clear).
And I really like the visual of the old version to the new one.
Good evening @cicoub13
I really like the idea of the button to update all integrations. I also find it practical that some developers have applied this logic: without any selection, everything is selected by default, and if selections are made, then only those are updated.
Have a great evening everyone,
Jean
It would indeed be convenient to be able to update from the list of integrations, globally.
But there is still a somewhat delicate situation: updating is triggered from the integration supervision page, but then I take the time to check if devices also need updating. And it seems necessary to do this consciously, because if the device update adds new features, I want to decide whether or not to keep their history.
So the ideal would be a global update button for all integrations, but with a report specifying if features have been added.
What do you think?
I just came across this via the integration dashboard: GitHub - b3n0/gladys-integrations_manager · GitHub
Itâs not old (4 days), does anyone know about it?
Yes, thatâs my attempt, explained here: Filtrer la page des intĂ©grations externes - #12 par b3n.0
Along the same lines, couldnât we consider a global supervision page for integrations, or failing that, a simplified and filtered view of the list of integrations, which would group all the actions currently available in the Supervision tab of each integration?
The goal would be to be able to manage integrations directly from a single page, without having to open each module and then navigate to its Supervision tab to perform an action.
This view could take the form of a compact table, without images or descriptions, showing the installed integrations, their versions, and the available actions (start, stop, restart, update, view logs, uninstall, etc.).
This would notably allow launching updates directly from the list, while centralizing other supervision operations, and thus easily removing integrations that one has installed just to see what they allow to do!
Development in progress (option button on each card) here feat(integrations): update a community integration from its catalog card by cicoub13 · Pull Request #3252 · GladysAssistant/Gladys · GitHub
You can test the rendering and functionality here (for those who have a Gladys Plus account) Gladys Assistant
So cool!!
Tested!
Works perfectly
Thanks
It works very well, thank you @cicoub13. And the small message confirming the successful update is clean.
This wasnât the case for the integration I tested, but if devices need to be updated after the integration update, could a message appear right below? But maybe itâs already included in your devt?
I donât think this is formalized in the manifest or the external integration version, so no way to detect it. Iâll check.
